Thread: Re-Filling after Renovation: Chlorine vs Salt
    Jul 2013
    Puerto Rico
    76
    Hi!
    I am completing a pool renovation (re-plastering, water line, etc.). I changed my pool to salt over a year ago (and love it) but the Pool Contractor recommends that (when re-filling the pool) I run the system on Chlorine for a couple of weeks before switching to Salt again (no specific reason beyond "That's what I've always seen & done).
    I have a Hayward Aqua Plus system.
    Please feed back.
    Thanks!
    S21
    Pool: 6,500gal Plaster (Pool & Spa), Capsule Shape, 25ft x 8ft, 3ft to 5ft depth
    Spa: 6ft diameter, 3ft deep
    Equipment: Hayward DE3620 Filter, EcoStar VS Pump, Aqua Plus Controls & SWG
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,025
    Re: Re-Filling after Renovation: Chlorine vs Salt
    your contractor is telling you the truth. Adding salt to a newly plaster pool isnt good for the plaster.
    To be on the safe side, you should probably wait 1 month before adding salt.
    Here is a link to what happens by OnBalance.
    When Should Salt be Added?
    Divin Dave,
