Thread: Tiny Hole In Skimmer
    Apr 2015
    Neptune Beach
    4
    What is the purpose of this hole in my skimmer? It's the opposite side of the weir door and about the diameter of my pinky.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,197
    Re: Tiny Hole In Skimmer
    Welcome to TFP!!
    My gut feeling would be an overflow/overfill drain, but that is just a guess.
    Support the site
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,550
    Maybe your finger is just bigger than mine, but I have a hole there just like that in one of my skimmers. It has a 1/2 pipe that goes back to the equipment pad and allow we to fill the pool via an automated valve. In my other skimmer, the same hole is plugged.
    Nov 2015
    Baton Rouge
    1
    It's an overflow/drain on mine.
    Jan 2016
    Melbourne, Victoria. Australia
    8
    Just guessing, but could it be a secondary inlet as a safety feature to prevent too much vacuum causing a small child etc. getting stuck to the skimmer if they lean up against it or in it?
    Fibreglass 48000 litre in-ground. Viron P320 EVO variable speed pump. EVO HEAT Force 18 heat pump. 32" Zodiac sand filter. Pool Controls Gemini 6+ Sanitizer & pH management system & SWG. Waterco auto water leveller. Paramount Vantage in-floor cleaning system. SR Smith 'Turbo Twister' water slide. Taylor K-2006 test kit.
    Build details at Not quite under construction anymore. Just a few things to finish off.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,763
    It is an overflow. That is a standard location of installing one. In a rare case that could be a filler line to add water to the pool but that is much less likely.
    The water level should not be that high if that is an overflow. If you have an autofiller, check to make sure it isn't stuck open and you are dumping water down the drain.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
