Results 1 to 8 of 8
Thread: What is this? Calcium?
    Jan 2015
    FL
    13
    I just noticed this today. I had a new pebble finish put in back in June/July and have kept the PH around 7.2 till Dec/Jan only recently did I move it up to a more normal level. It is currently 7.5, and my Cal is at 350ppm. I just noticed today some sort of white rings developing around the perimeter of the individual pebbles. Anyone know what this is? or what to do about it? In some places its really not that noticeable and in others its worse. It seems to be the most pronounced right below the skimmer.
    IMG_2252 by maleora99, on Flickr
    IMG_2251 by maleora99, on Flickr
    IMG_2250 by maleora99, on Flickr
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: What is this? Calcium?
    Do you have a full set of test results?
    Support the site
    JoyfulNoise's Avatar
    May 2015
    13,199
    Also, what type of pebble coating is that as it does not look like a standard PebbleTek (TM) coating. There's a lot of plaster in those pictures and very little exposed aggregate.
    Matt
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    It also looks polished or sanded too like a quartz finish.... nothing like a typical pebble finish
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Jan 2015
    FL
    13
    This was a NPT stonescapes pebble finish. I had the same questions as you about the amount of exposed pebble - which is much less than the sample board. I was told by a warrently rep and another installer (not the one I used) that this is normal... and that the samples always have much more exposure. Keep in mind these photos are also very close up.
    It is possible that there wasn't enough exposure initially - the pool was completed with a hot start up - but again every expert I called for a 2nd opinion told me it looks the way it is supposed to. *shrug*
    Anyway...
    A fresh run of tests gave the following results
    FC 5
    CC .5
    Cal 325
    TA - 60 (this is low)
    CYA - 24 (really low)
    PH - 7.5
    The pool is currently on chlorine - I was going to reactivate my salt system today and was checking the pool before heading out to the store for supplies when I found this. I held off because I didn't want to go messing with any other variables till I could determine what was going on.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,465
    How did you get your test results?
    Has your PH been stable? If so it might like the TA where it is. Every pool is very different in this regard.
    Kim
    May 2015
    13,199
    Your picture looks nothing like the images on the NPT website. If your entire pool looks like that, then I seriously think the applicator screwed up the aggregate-to-plaster mix.
    Have you contacted NPT about this? They should have the final say in what constitutes a proper aggregate density and exposure.
    As for the white halo's around the pebbles, it's really hard to say. It almost looks like the plaster has lost/leached its color. If it's raised, then maybe it's calcium deposits from the underlying plaster and the interface between the pebble and plaster is allowing calcium to leach through and form calcium carbonate. I would expect the crevice to eventually seal up and stop growing but it's hard to say.
    If you apply a small amount of diluted muriatic acid to the area (like a underwater acid etch) does the white halo go away?
    Matt
    Matt
    Jan 2015
    las vegas
    92
    Unfortunately if you paid for stonescapes pebble this is far from an acceptable application. You should contact the distributor directly and get a third opinion. I agree with above, it looks more like a polished product, maybe Wet Edge Primera Stone.
