Thread: CH sample tube level?
    Oct 2015
    Orinda, California
    56
    I have a TF-100 test kit and the instructions says to fill clear plastic cylinder to 10 ml mark. I previously printed out a pdf file forum and says to fill to 25 ml mark (10 ml) The open and close paren use for very high CH. My CH is ~ 280. Should I fill to 10 or 25 ml mark? I must be misreading or interrupting instructions incorrectly. Thanks
    28,000 gallon IG pool, plaster, built approx. 1970.
    1 1/2 " plumbing. Pentair, Intelliflo 3 hp variable speed.
    Crystal Water cartridge filter system, model #425
    Dolphin Deluxe 4,
    Jun 2014
    15,103
    Re: CH sample tube level?
    Both the TF-100 card and Extended Test Kit Directions show 10ml. Please use the 10ml mark. Have a nice day.
    PS ~ We are required to multiply our drops by 25. Perhaps that was the confusion? Or.... please see next two replies.
    Donldson's Avatar
    NW Ohio
    2,893
    You can use either. With the 25 ml sample each drop equals 10 ppm, and with the 10 ml sample each drop equals 25 ppm. Generally knowing your calcium level to the nearest 25 ppm is good enough.
    From my HTC One via Tapatalk
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Jun 2014
    15,103
    I missed the note at the bottom:
    If you expect that your CH level is very low, you can do the test so that each drop is 10, instead of 25, to get some extra precision. Use 25 ml of pool water, 20 drops of R-0010, 5 drops of R-0011L, and multiply the number of drops of R-0012 by 10 to get your CH level.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    The smaller sample size is suggested to save reagent and time running the sample. 10 isn't wrong, but at 280 PPM I would prefer running the 25 ml sample if it were my pool. It's not critical, but you do lose accuracy with the smaller sample size, and 25 ml sample won't use much reagent anyway. It holds true for all the reagents, because you aren't spending much time or money compared to the value that accurate testing and balancing brings to the table.
    Essential Links:
