Thread: Hayward Pump SP2610X15 vs SPX version
    Central Connecticut
    159
    Does anyone know the physical difference, if any, between the Hayward Super Pump model with the "X" after the SP and without? Ie., SPX2610X15 vs SP2610X15 ?
    Rich
    18x36 IG 26,000 gal, Vinyl Liner, 24" Sand filter Hayward S224T, Jandy AE3000 heatpump and 1.5 HP SuperPump. Circupool RJ45 SWG
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Hayward Pump SP2610X15 vs SPX version
    Where did you see SPX2610X15 used? Generally the parts of the SuperPump start with SPX so it should not be used for the entire pump. See page 11:
    http://www.hayward-pool.com/pdf/manuals/SuperPump.pdf
    Mark
