Results 1 to 7 of 7
Thread: Test discrepancy - OTO vs FASDPD
    bdrums's Avatar
    Jul 2015
    The Woodlands, TX
    251
    Tested Friday evening and the FAS/DPD test showed FC at 1.5 and that I needed to add 68 oz of 8.25% bleach to get to my target of 4.0. I only had 48 oz so I added that and intended to get to the store Saturday morning.
    Tested Saturday morning . Usually I skip the OTO test because I have a bit of difficulty distinguishing the deeper shades of yellow so I just do the FAS/DPD test. This time however I decided to give the OTO test a go as well.
    The OTO test showed a light shade of yellow. Best my eyes could tell, not more than 2.0 TC.
    The FAS/DPD test showed FC of 4.0 and CC of 0.
    Hmmm... that doesn't mesh. I had used 2 scoops for the FAS/DPD test and it turned a deep red. So I decided to re run the test and used just 1 heaping scoop. Same result.
    I wasn't expecting a FC result of 4 since I hadn't added enough bleach according to the calculator.
    I bought the test kit last August. It stays in the 2nd bedroom closet. I'm low of the powder as I test about 3 times per week so I definitely need more.
    Thoughts? Thanks!
    Build thread
    IG Gunite w/ spa, PebbleSheen Blue Surf, 18K gallons 500sqft
    Jandy: 60 DE filter, 2.0 VS (main pump), 2.0 Flo Pro (features)
    Paramount PV3 w/ 1.5 Stealth, PDA PS6, JXi 400K NG
    Flagstone coping & wall. Stamped Concrete from BrickForm. TF-100 w/Speed Stir.
    Aug 2014
    Shallotte, NC
    693
    Re: Test discrepancy - OTO vs FASDPD
    I would trust the FAS/DPD test. If the FAS/DPD powder turns deep red, it means you have "more" chlorine rather than less. You might want to double check the size of your pool in the calculator.
    bdrums's Avatar
    Jul 2015
    The Woodlands, TX
    251
    Thanks. I tend to trust the FAS/DPD test as well. Was just curious why the OTO test showed so different.
    The volume I use in the calculator is what the builder provided from the CAD software. My guess is that it's probably within a few % of actual. Isn't that normally good enough?
    Aug 2014
    Shallotte, NC
    693
    Quote Originally Posted by bdrums View Post
    Yes, it is! However, I usually get myself in trouble trying to answer another poster's question and forget to change back from "their pool" to "my pool."
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    OTO is just a color comparison, and doesn't specify TC or FC. If you want accurate specifics, just use the FAS DPD FC test.
    Essential Links:
    30,414
    As always, use the OTO to test for the presence of chlorine and maybe a rough idea of how much is there but you are mainly testing that there is chlorine in the pool.
    When you need to know exactly how much FC is in the pool, you use the FAS/DPD.
    OTO for presence - FAS/DPD for precision.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    ^^^ yup. What they said.
    Divin Dave,
