Results 1 to 8 of 8
Thread: seasoning infrared grill
    banditig's Avatar
    Sep 2015
    Ohio
    466
    I have a char broil infrared gas grill with stainless steel vavy grates with small holes. I used canola oil like the manual sugested to "season" it like iron skillets. Now the grates are black and some holes plugged up after just a few uses. Did I use too much oil or get it too hot?
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: seasoning infrared grill
    Without really knowing, it sounds like a design issue unless you really slathered it on thick during the seasoning process.
    Essential Links:
    Aug 2014
    Shallotte, NC
    693
    Think of it as grandma's old cast iron pan. That coating of baked-on oil is an ancient form of teflon. Now, plugged holes? Yeah, maybe a little too thick. Two light coats of oil is better than one thick. I think you could just take an ice pick and carefully clear the holes.
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    I had one of those and loved it. The grates just don't last long. I'd suggest unplugging the holes with a toothpick. That's what I did to mine.
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Thanks all! cleaned the holes and grates. Two light coats and it looks much better.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Awesome, now it's time to get back on it and whip us up something good!
    Essential Links:
    AUSpool's Avatar
    Sep 2015
    Sunshine Coast, Australia.
    355
    I have a Char Broil 3 burner infrared and can't remember if I seasoned mine or not. I thought seasoning was done with oil and salt. Mine has the wavy emitters with cast iron porcelain grates on top. I turn it up to max and let it smoke away before using it every time. When it's real hot I give it a scrub with a stainless steel brush and then spray it with plain water from a spray bottle which turns instantly to steam.
    I like my teriyaki and regularly do a brined chicken in ponzu, olive oil and fresh herbs. When I get arround to cleaning the emitters I need to use one of my old chisels and a lot of elbow grease, they're never going to look like they did when the they where new.
    I noticed just then when going back to the char broil site that my emitters are upside down with the holes on the bottom. Next time I clean it I'll turn them around but I doubt it will make much difference since my holes are almost always blocked anyway.
    Steve.
    30,000L (8,000g) Pebblecrete | Davey 3sp Eco pump | Poolrite sand filter & SWCG |
    Waterco solar panels & Astral E140 pump| K2006, BlueDevil pH, Salt meter & K1766 | Town water - pH 7.2, TA 50, CH 60 | Esky full of coldies |
    May 2014
    Clarksburg, WV
    331
    I have the same grill.
    Mine rusted out within 2 years. They say stainless, but they are definitely not stainless. Hopefully yours last.
    24'x54" 15k AG round - Outback Genesis
    1 1/2hp Hayward Matrix 2 speed. Hayward 180T Sand Filter
    TF-100 Test Kit
    Pool School & TF-100
    How to SLAM
