- Oct 25, 2015
- 5,275
- Plaster
- CircuPool RJ-60 Plus
Folks,
I've noticed something weird happening with my FC test. I've been using the TF 100 tests since Nov of last year. When I run the FC test and add 0871 to get a clear solution the solution is cloudy. Used to be clear and the kit is only 4 months old so I doubt reagents are a problem. Just to be sure I tested my neighbors pool water and the test is crystal clear just like it used to be for me. My FC level has been high as I completed a SLAM 2 weeks ago and we've had unseasonably cold water so the FC level is dropping much slower than normal. I've had high FC levels before and the cloudy test didn't happen. None of this seems to affect my pool which has been crystal clear throughout. My last couple of weeks test data (starting with the SLAM) are shown below. The only other thing I've done is partially add my chlorine with trichlor to get the CYA levels up from <20. It's worked well and when I reach 40 I'll switch back to bleach only.
As far as I can tell this isn't affecting the pool at all but I'm curious what's causing this.
Any comments would be much appreciated.
Chris
Chris
Date | TA | CYA | FC | CC | CH | PH | Actions/Observations |
9-Jan-16 | ***Start SLAM***Added 128 oz muratic, scrubbed pool 8am, noon PH reading 7.1 added 128 oz 10% CL bleach, 1pm FC 18, PH 7.4 started solar heater pump pr 15 psi, 3p FC 21 PH 7.4, 1130 pm PH 7.4 FC 21 | ||||||
10-Jan-16 | 20.5 | 0 | 7.5 | 7 am readings to left, 3 pm FC 19, 8 PM FC 17.5 CC 0 PH 7.5 | |||
11-Jan-16 | 16.5 | 0.0 | 7.6 | OCLT-0, 2:30 pm readings to left | |||
12-Jan-16 | OCLT-0, ***SLAM OVER*** | ||||||
13-Jan-16 | Lot of Rain | ||||||
14-Jan-16 | Lot of Rain | ||||||
15-Jan-16 | 13 | 0 | 7.7 | Lot of Rain | |||
16-Jan-16 | 12 | 0 | Clear Day | ||||
17-Jan-16 | 10 | 0 | 7.7 | Clear Day | |||
18-Jan-16 | 9.5 | 0 | 7.7 | Partly Cloudy | |||
19-Jan-16 | 9 | 0 | 7.7 | Clear Day | |||
20-Jan-16 | 8.5 | 0 | 7.7 | Clear Day | |||
21-Jan-16 | COLD | ||||||
22-Jan-16 | COLD | ||||||
23-Jan-16 | 5+ | 7.7 | OTO FC 5+ | ||||
24-Jan-16 | 60 | 35 | 6.5 | 0 | 275 | 7.8 | Clear Cold-Added 3 tablets to chlorinator setting 0 |
25-Jan-16 | Cloudy | ||||||
26-Jan-16 | 6 | 0 | 7.7 | Rain! | |||
27-Jan-16 | 5.5 | 0 | 7.7 | Rain- rem 4" water | |||
28-Jan-16 | 6 | 0 | 7.7 | COLD | |||
29-Jan-16 | 35 | 6 | 0 | 7.7 | COLD | ||
30-Jan-16 | 8 | 0 | 7.7 | ||||
31-Jan-16 | 10 | 0 | 7.7 | warmer | |||
1-Feb-16 | warmer | ||||||
2-Feb-16 | 9 | 0 | 7.7 | warm | |||
3-Feb-16 | 7 | 0 | 7.7 | warm | |||
4-Feb-16 | 6.5 | 0 | 7.6 | warm |
