Thread: Filling drained pool with a little green water in the bottom
    Jan 2016
    cave creek, az
    4
    My friend emptied his pool for repairs. After the repairs, we got some rain and it left about 6 inches of water in the deep end of the pool. That water has since turned green. He wants to refill his pool, does he need to drain the green water before starting? Or would you just fill the pool, add chemicals, and run the filter for a while? Thanks.
    17,000 gallons, IG, plaster, cartridge. Installed in 2013.
    Oct 2015
    Katy/Texas
    411
    Re: Filling drained pool with a little green water in the bottom
    Seems to me it would be prudent to kill the algae before adding more water and spreading it around.
    In ground, 14,000 gallon, white plaster, unheated, stone waterfall, DE Filter, Rainbow 320 Cl, Polaris 3900, FloVis flow meter, F100 test kit, Circupool RJ30+ SWG, Circupool VJ1/Speck Badu EcoM3V variable speed pump.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,458
    If a sump pump is available then I would pump it out just for good measure. But, pumped out or not, be prepared to SLAM the pool as soon as it is full. Here's how, Pool School - SLAM - Shock Level And Maintain
    30,404
    Fill the pool as is. You cannot rid a pool of algae....even by almost a complete drain. The conditions for algae still exist in your pool whether or not you drain off the water.
    So to answer the question correctly, we need to know the size of your friends pool so we can suggest an addition of Clorox while the pool is filling. Your friend will then need to SLAM the pool per the article in Pool School.
    In short, draining or not draining that remaining water makes little difference.....you'll still get algae unless you SLAM the pool.
    Jan 2016
    cave creek, az
    4
    Thanks for the advice everyone.
