Results 1 to 11 of 11
Thread: Took a break
    Jaxcmc's Avatar
    Jan 2016
    Macclenny Florida
    31
    Took a break
    I took a break from rebuilding my pool pumping station and smoked a brisket in my box smoker. I used half cherry and half apple wood chips.
    47k, 40x20 IG plaster,SWG, 24 jets, 3HP Pentair Whisperflo 2 speed,Hayward Pro Series Sand Filter36" Tank S360T2 TF-100
    Dec 2015
    Chino/CA
    203
    Re: Took a break
    How many hours and at what temp?
    Chris B.
    New house w/ 28 y/o I.G. 15k gal. pool/spa, Plaster, Hayward DE-480S Micro Clear Filter, Pentair Whisperflo wfe-4, 1HP (Main Pump), Hayward SP2815x20 (Pump for spa jets), Versa Pool Heater, Hayward Pool Vac Ultra, TF-100 Kit
    Jun 2014
    15,121
    Re: Took a break
    Awesome! Looks great. We just smoked a brisket yesterday ourselves. Had left-overs for lunch.
    Jaxcmc's Avatar
    Jan 2016
    Macclenny Florida
    31
    Re: Took a break
    It was around 11 hours at 200-225. I didn't have any leftovers as my sons band showed up to practice.
    Oct 2015
    Katy/Texas
    411
    Re: Took a break
    Sure looks good. Now I have brisket cravings.
    In ground, 14,000 gallon, white plaster, unheated, stone waterfall, DE Filter, Rainbow 320 Cl, Polaris 3900, FloVis flow meter, F100 test kit, Circupool RJ30+ SWG, Circupool VJ1/Speck Badu EcoM3V variable speed pump.
    Dec 2015
    Chino/CA
    203
    Re: Took a break
    Nice!!!
    What setup are you using? I'm also a "smoker" LoL
    Chris B.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,491
    Re: Took a break
    Yum! Meat!
    My newest fave wood for brisket is pecan.
    Jun 2014
    15,121
    Re: Took a break
    Did our brisket in our Trager grill. Mesquite flavored pellets. Smoked at 225 degrees for 4 hours, then removed and sprayed with water and Worcestershire sauce, then wrap in butcher paper and smoked again until internal temp was 198 degrees (that took about another 5 hours or so). Our brisket was 12 lbs. Tasty!
    Jaxcmc's Avatar
    Jan 2016
    Macclenny Florida
    31
    Re: Took a break
    I cook mine fat cap down, with thick cut bacon layer across the top at 200. After 5hours I wrap it in foil for another 5 hours or so until 195 degrees. I like to use "Butchers" rub and injection....I tired making my own rub..didn't turn out so good.....
    Quote Originally Posted by pooldv View Post
    Yum! Meat!
    your right ...pecan is awesome with beef.....
    Jaxcmc's Avatar
    Jan 2016
    Macclenny Florida
    31
    Re: Took a break
    Quote Originally Posted by bakerboy View Post
    Nice!!!
    I am using a 40" Grill Master that has been gutted. Didn't like any of the insides, so I replaced the wood chips bowl, water pan. Nothing fancy but we know,each other....your rig?
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Took a break
    Looks great
