Thread: Motor just hums... won't start
    Feb 2016
    Wellington, FL
    1
    Moderator note - Moved from this post: Help. Motor just hums... won't start - Page 2
    Just installed a new century 1 HP last night - worked fine when complete.
    Came out this morning to find it off even though on timer. Let it cool a bit and it started humming. Pulled it from the pump and found the impeller not moving but able to turn. Made different noises based on turn position.
    Then I spun it quickly and it started working.
    Of course I put back into place and again it does work just hums.
    Does the Cap give it an extra shot of power on start up? Does this sound like the issue?
    Like to know if I have any options before buying another motor.
    Thanks
    Joe
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Re: Motor just hums... won't start
    Quote Originally Posted by jsheehan3 View Post
    If it is new, i wouldn't waste time with it. Warranty it!
    Without getting complicated, yes.
    Factory Warranty Station for:
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,187
    I will also point out that until you get the pump sorted out remember you need to find a way to circulate the water and keep the chlorine level up. Even in "winter", pool water in Palm Beach County doesn't get cold enough to keep the algae
    Support the site
    Jul 2015
    Tempe, Az
    123
    Hmm.....something is amiss if it smoked the capacitor on the first day.
    Did it get rained on? Although it is a pool pump for water, I've found that these things still don't like getting wet. Might not hurt to hit all of the electrical connections with silicone grease too, since you have high humidity in FLA.
    Did you replace a 220V setup with a 115V motor by accident?
    I 2nd getting a warranty replacement, and I'd recommend spending $15 or $20 and getting a spare capacitor anyway. At least this way you have one on hand "just in case"
    28K Gallon old-skool plaster hole in the back yard in desperate need of an acid wash and a fixed skimmer diverter (yes, it's still broken)
    Hayward SuperPumpVS pushing some giant hayward cartridge filter setup
    SharcVacXL and Zodiac G2 to keep things clean
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Welcome to the forum jsheehan3
    Please add your pool and equipment info into your signature as outlined here - - > Pool School - Getting Started
    Solar Blanket, Well Water, Borax Added. 68
