Results 1 to 17 of 17
Thread: How deep for tanning ledges?
    Dec 2014
    Cypress, Texas
    200
    Our pool will have a 8x6 tanning ledge, and I was talking to the PB and he said it was drawn to be 9" deep with 6" of water.
    I'm wondering if 6" of water is deep enough? If you have a tanning ledge, how deep is the water and is that the right depth for you, or would you like it to be another depth?
    2016 Build: 32x8 Gunite, 6,700 gallon IG pool including 6x8 spa and 6x8 tanning ledge w/ 2 bubblers. 32' raised wall with two sheer descent water features. Travertine Coping w/ split faced Travertine on raised wall face. 2HP VS Jandy pump, 400k heater, Rainbow Chlorinator, 4 Colored LED Lights. 459sqft spray deck plus. IAqualink remote, Polarus 9350 Robot Cleaner.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: How deep for tanning ledges?
    Mine is 6ish and more would be better. There are lots of people with 6"-18" deep ledges and 9-12" seems like it would be best to me. Maybe sit down and measure where the water will be at different depths and if you already have an idea of what chaises or furniture you might put on it. We don't have furniture on ours. We stand and sit on it and dive from it and our dogs stand on it.
    Dec 2014
    Cypress, Texas
    200
    Quote Originally Posted by pooldv View Post
    I was thinking more also, but the PB was worried that the bubblers wouldn't look right. Hmmm, I don't even know that I need the bubblers. Opinions?
    Helen203's Avatar
    Jul 2015
    Annapolis, MD
    819
    Quote Originally Posted by Mamiamjo View Post
    So my PB said 9" max for bubblers. We skipped the bubblers and went 12 inches deep. We have a return that circulates water off of the shelf.
    My Pool Build (2015): inground 12K gals gunite/plaster pool, SWG, 2-speed pump, cartridge filter, gas heater, and Dolphon s300i. TF-100 Test Kit w/ Speed Stir
    Dec 2014
    Cypress, Texas
    200
    I was thinking 9"-12" would be better. Anyone have 9"-12" deep Tanning Ledge?
    Another question then is do we need the bubblers? Do they do much to add to water circulation or would the return jets be enough?
    Nov 2015
    Humble
    101
    I spec'ed 9" for mine.
    IG Gunite, 16' x 30', 3 1/2' - 5' deep, ~11K gal, Pebblesheen, Intelliflo VS pump, Clean and Clear 420 Filter, LED Color Lights, Taylor K2006 Test Kit.
    Build thread http://www.troublefreepool.com/threa...d-in-Humble-TX
    May 2015
    Naples/FLORIDA
    82
    I have two sun decks. One is 9" deep with two bubblers and the other one is 18" deep and meant for adults to be able to sit there and relax with water coming up chest high
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    My ledge is closer to 16 inches. When we put our standard deck recliners on the ledge the water comes right level with the seats. We are happy with the deeper water on the ledge. We also have a bench at the same level along the length of the pool. It seems just right to sit on the bench and set your drink on the deck.
    chiefwej
    Dec 2014
    Cypress, Texas
    200
    Quote Originally Posted by hhuang2620 View Post
    How do you use the sun deck with 9" water? Do you use loungers? In your opinion, are the bubblers of any use with 9" deep water?
    Thanks
    DFW, TX
    24,450
    Just fyi, one thing bubblers will do is raise your PH through aeration.
    May 2015
    Naples/FLORIDA
    82
    Thanks
    I have not used any lounge chairs yet. Mainly kids play area for now but 9" is not that deep so low lounge chairs should work fine. Yes, the bubblers work just fine with 9" of water. I mean they aren't spraying out like a fountain but they bubble enough to give the effects and sound I want and plenty of fun for my kids.
    platipus's Avatar
    Feb 2015
    Houston, TX
    374
    Same issue/questions came up in our design. We wanted a deeper shelf and bubblers, but bubblers seem to work best (we are told) at 9" or less depth. So this is what I did in our design (still waiting on permits). In the design, I put a 2' wide first step as the entry to our sun shelf and am going to put a bubbler right on the edge of that step. That way we get at least one bubbler in very shallow water. I still have one other bubbler on the main shelf as well in the deeper water. I'll ask for them to be run on their own lines with valves so I can adjust them independently. Maybe the deeper one we just leave off. Who knows. That was the best compromise I could come up with.
    As far as the actual main sun shelf depth, we wanted a deeper one then optimal bubbler depth so we are doing 12". I would even go a little deeper than that if I could, but it's for the dogs as much as it us for us, so going much deeper than that is not practical for the smaller dogs. We did however plan for a decent amount of 18"-ish deep bench seating so we will end up with the best of both worlds.
    When it came to depth, ignoring the bubbler issue, these are the questions I asked myself:
    Need it shallow for little kids? - No. Deeper then.
    Are we going to put a chez lounge on it and tan, thereby wanting to keep the lounge webbing out out of the water so you don't drown when face down? - No. Deeper then.
    Do we want more than just the bottom of our posteriors to be wet when sitting in beach style chairs? Yes. Deeper then.
    I kind of seeing us using the sun shelf space when we want to be "in the pool" but also read a book or have an iPad. For me personally, that means water up to just below my waist when reclined on a low chair. 16" is the depth I would actually go with if I could, but again dogs... So 12" it is.
    plat.
    Modern Geometric-ish Social Pool (4'-5'-4') ~13' x 47'. Sun shelf. Perimeter overflow spa. RiverFlow Swimjet. Dog ramp. "Bubble Lounge"
    Link to my patio build, completed 2013
    Link to my pool build, Aug '15 - Sep '16
    Helen203's Avatar
    Jul 2015
    Annapolis, MD
    819
    Plat, you really thought this through! I just wanted a place to sit and read with my feet in the water.
    Jan 2016
    TX
    157
    Not sure of the exact depth.. but the one we are in the process of building is a full step in depth below the first entry step into the pool. I wanted to be able to sit on the ledge and be chest high in the water. If I want to tan I'll sit in the sun out of the pool... not really any desire to just get my butt wet while tanning.
    Gunite Pool/Spa, CLI Caribbean blue crystal stone smooth, Pentair 3hp Intellifo VS, Pentair Quad DE Filter, Pentair 400k BTU Heater, KK Prowler 820, Pentair PSL4 controler with Screenlogic wifi, Inline Chlorinator, Pentair 1.5hp Spa Blower, TF-100 Test Kit w/ Speed Stir. My 2016 Pool Build
    May 2015
    Fullerton, CA
    634
    We went 16" deep.
    33x19, 3'4"-5'6", 7ft spa, baja reef, 14'x9', 18" deep, 10,668 Gal. Quartzite coping, Stonescape Tropics Blue mini-pebble, abalone & glass beads. Jandy Equip.(JXi heater, 2.7HPVS pump, PLC1400 SWG, CV580 filter, Aqualink, LEDs)
    TF-100, Doheny Discovery robot.
    Sep 2015
    Mesa, AZ
    305
    I have one that is 16" and one that is 9"
    Freeform /620 Surface/110 perimeter/20k gal/ Raised bond beam/Baja shelf (2)//Pentair- Intelliflo VS pump, Pentair Whisperflo 1hp// Easytouch, C&C 520 Cartridge, Intellichlor SWCG// A&A- Magnasweep in-floor, LeafVac, Venturi Skimmer,// Mini-pebble (Aqua Blue w abalone shell)//4 Pentair Globrite LEDs//3 sheer descents//Travertine coping and decking.
    Aug 2014
    Houston tx
    2,524
    Ours was going to be 12" I think but we got rid of it to make room for more pool.
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
