Thread: Solar temp control vs Automation?
    Sep 2015
    Orlando, FL
    33
    About to get solar installed for new build, company suggested their automatic temperature "set it/forget about it" control ($500).
    I like the idea, yet I'm also having an upgraded automation installed for pool. Like many models, it has a relay slot for solar, and 3 temperature sensors.
    Is the solar control redundant?
    16k gal, IG, marcite, 3HP VSP Ecostar, 2HP Booster 2speed, 200 sqft cartridge, SWG, Caretaker IFC, Omnilogic, Solar, Taylor K2006, Born 3/16
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Solar temp control vs Automation?
    Probably so, most pool automation has the ability to control solar. All that is needed to control solar is panel temp, water temp and the ability to open the solar valve. Mine also rampsmup yhe speed on my VS pump. I would definitely read up on your automation package before buying a solar controller. Most mfg have manuals available for download on their websites
