Thread: HOw thick is the ice in the winter?
    Apr 2015
    South Central PA
    297
    Anyone have any idea how thick the ice gets during the average winter? I know it can vary, just wondering if it's 1/2" or 5"...I'm in central PA, near the MD border. I think I'm going to need to drain some water soon. I have a mesh cover that's weighed down ice after the big snow, so I don't want to take any of the anchors off now- the springs are really loaded. I'm wondering if I can easily break the ice and use a submersible pump after the cover ice melts.
    20000 gallon vinyl liner in ground pool
    16' X 34' rectangular diving pool
    Hayward Pro Grid DE Filter
    Hayward 1 hp Super Pump
    TF-100 Test Kit Stenner 45MPHP10
    Aug 2014
    Northern IL
    4,615
    Re: HOw thick is the ice in the winter?
    Yea, it depends. I would be very careful about breaking the ice. My strategy is to watch carefully for thaws so I can at least to a partial cover drain. I also bring my submersible and hose into the garage to de-ice them occasionally.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Yuck! Ya'll all need to move!
    Oct 2013
    Iowa
    82
    Even if you could safely break some of the ice I'm not sure you want to lower the water when there is much ice. It seems like you could get end up with ice suspended on something causing something to break or rip. I would wait until it mostly thaws and deal with lowering it then. We have a solid cover but I understand a mesh cover should have enough stretch or spring that most of the snow/ice weight is held up by the water/ice in the pool the same way a solid cover works. Last spring I watched pretty closely and the ice melted near the sides first so I was able to stick my hand in after it had melted back from the side some and found it was at least 4" thick on the edges even after a lot of melting. I would guess it is at least that thick now if not thicker as the average temp has been below freezing for a long time now. I am not sure how IA compares to PA but it seems like they would be similar.
    20,000gal in-ground 16x36 sentry pools vinyl liner, Pentair sand filter, Pentair minimax NT heater, auto-cover, Polaris 280 cleaner.
    Apr 2015
    South Central PA
    297
    Thanks...it's not so much the cover I'm concerned about. It's the pool getting too much water in it...In the area by the steps where the vinyl seam meets the steps, there appears to be a separation that would allow water out before the pool overflows (it's not an issue for normal water level). I want to get pictures and post on here for opinions, but that will have to wait until I can peel the cover back. I think you're right about ice suspended on something...that wouldn't be good....
