Thread: Anybody use SPAZAZZ in their hottubs?
    Jan 2016
    Crownsville, MD
    10
    I'd like to know if anybody's used Spazazz in their hotubs. Pros & Cons Please.
    Will it effect water balance or chlorine sanitation process
    Thanks
    2015 Bullfrog A8
    540 gallons
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Anybody use SPAZAZZ in their hottubs?
    Nope, but we've been using epsom salts scented with mint, green tea, eucalyptus, etc for a couple of years. No apparent side effects so far. We use the How do I use Chlorine in my Spa (or pool)? method with great success.
    Jan 2016
    Crownsville, MD
    10
    Quote Originally Posted by pooldv View Post
    Good to hear. I've only had the hot tub for 3 weeks. I bought some Spazazz before thinking what it might do to the water, but I know salt water isn't friendly to metal parts. Been fighting the foam right now and I'm working towards liquid chlorine. I'M still learning how to control the tub water. Everything seems to be ok other than the foam I need to get the hardness checked.
    Thanks
    2015 Bullfrog A8
    540 gallons
    DFW, TX
    24,450
    Yep, test the hardness and raise it to 150ppm or so to help with foaming. Nearly all, if not all, pool and spa equipment is compatible with salt water.
