Thread: Advice needed contractor selected South Louisiana
    Jan 2016
    Hahnville/Louisiana
    5
    I found my PB. Here is my equipment list and particulars. Am I missing anything?
    Aprox 500 sqft gunitefree form 17000-18000 gallons.
    Tan ledge, Bench seating, stairs
    8 round spa attached to overflow
    Pentair whisperflo energy efficient 2 HP pump (pool)
    Pentair whisperflo energy efficient 1.5 HP (spa waterfall)
    Pentair booster pump HP (pool cleaner)
    Polaris 280
    Master temp 400,000 btu gas heater
    Pentair clean n clear plus cartridge filter
    Automated pool panel with remote
    Aquarite salt chlorine generator w/flow switch
    2 intel brite led pool lights
    I intel spa light
    600 sqft paver decking
    Electrical for pumps
    Gas line for heater (approx. 20)
    Waterfall separate from price.
    Aug 2014
    Houston tx
    2,525
    Re: Advice needed contractor selected South Louisiana
    Do you have any pics you can post of the design and of your yard where the pool is going? We love pics here at TFP! I'm sure someone will be along to comment on your list. Welcome to TFP!
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Apr 2013
    Sacramento, CA
    2,769
    Consider deleting the Polaris pool sweep and booster pump. Get a Robot instead. Costs less to operate and cleans as well or better. A plan would be good. What are the spa specs?
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,620
    Make sure to get model numbers for all of your equpment.
    We would love to see your yard as it is now and the plans you PB gave you.
    Kim
