Results 1 to 11 of 11
Thread: Remove drive from Intelliflo
    Dec 2014
    Riverside California
    482
    Hello all. I just had a new Intelliflo VS installed. The electrical conduit connection is straight in, but for various reasons I would like to use a 90 degree conduit connection. The fan housing prevents this. I looks like I could just remove the drive assembly then put in my 90 degree conduit piece then re-install the drive. My question is am I in danger of messing up my new pump if I remove the drive? There is a gasket involved which the manual states is critical to prevent moisture from getting into the connector which joins the drive and the motor. Has anyone done this and had damage to the gasket? A replacement gasket only comes in a hardware kit for $60.00!
    Thanks!
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Remove drive from Intelliflo
    Sorry, I can't help with this question. But, here is a to see if we can get an answer.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,734
    I'm trying to picture why you need to remove the drive? I installed a 90 on both of my Intelliflos without doing any sort of surgery. Can you post a picture?
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Apr 2013
    Sacramento, CA
    2,769
    Are you talking about a 90 at the end of a whip?
    Dec 2014
    482
    This is the type I want to use:
    If I try to screw this into the threaded hole in the junction box it will hit the motor fan housing. I could remove the fan housing, but it has a screw underneath that would be difficult for me to access.
    If I can remove the drive, it would be very easy to attach my 90 degree connector.
    My question was, if I remove the drive do I take any risk of damaging the gasket between the motor and the drive. You have to buy a whole hardware kit just to get the gasket, and it is around $60.00.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,734
    That is the exact elbow Gwegan was referring to. It's a LiquidTite connector for a whip. I still don't understand why you need to remove the drive?
    -Brian-
    POOL BUILD
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,734
    This is an Intelliflo VS
    This is an Intelliflo XF
    No need to remove the drive on either...
    -Brian-
    POOL BUILD
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    Quote Originally Posted by bdavis466 View Post
    The elbow fitting wont screw in completely with the drive still attached.
    Before you begin, be sure that you turn all the power off to the drive before you disconnect the wires to the drive, then:
    Remove the three long bolts that are exposed when you open the door to the drive.
    Remove the drive by gently pulling straight up.
    There will be three grommets that will either stick to the drive end or the motor end, or both. Be sure to recover all three, and re-attach them to the motor end.
    Remove the old and install your new fitting.
    What i do to insure that the drive lines up to the plug correctly upon re-installation is pull one of the long bolts out of the cover, generally one of the top ones. Then i sight through the hole to the threads on the motor and line it up that way, because you want to make sure that the plug is lined up. The drive should plug in with little effort, if it don't, you're not lined up. Make your power connection and you're dun!
    Factory Warranty Station for:
    Dec 2014
    482
    How did you manage to screw in the 90 degree connector without removing the drive or fan housing?
    Quote Originally Posted by Pool Clown View Post
    Thanks Pool Clown. That is the exact info I need.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,734
    I just threaded them in on both pumps. It is a very tight fit but worked just fine. I'd add a 1/2" threaded extension before the elbow instead of pulling the drive from a brand new pump. I don't foresee any issues if you do choose to remove the drive but why go through the trouble?
    There are also larger radiused elbows that would clear without any issues.
    -Brian-
    POOL BUILD
    Dec 2014
    482
    Thanks everyone, very useful information. Following Pool Clown's great instructions, I was able to remove the drive and install the 90 degree fitting. Turned out to be very easy.
