Thread: Safety Mesh Cover
    Jul 2012
    North Atlanta
    22
    Safety Mesh Cover
    Hello
    I bought a safety mesh cover on CL for 100$ last October and couldn't wait to use it this winter Well here it is Feb 2 and the water is nasty Cant tell if it's green or Black
    The winter here in Atl hasn't been to cold but we have had alot of rain
    Couple of questions-
    Am I suppose to shut the pump off with this type of liner?? (I usually keep it open year round as I don't like the water getting like this)
    I closed the pump off for winter and blew the lines out with the skimmer jug plug as well
    Also I should have bought the solid cover This mesh material is the one where water can get through and it's not fun
    Thanks
    18x36 ig Vinyl 26000 gal
    30 Jandy Sand Filter
    2hp Pentair Challenger
    Hayward Chlorinator
    Dr. Hops's Avatar
    Feb 2015
    Canton, GA
    31
    Re: Safety Mesh Cover
    I live in Canton and had my pool turn black. I swept the walls and bottom and it was all just dirt, probably from all the rain. I added 2 lbs of shock, ran the pump for 24 hours with the pool vacuum inside the pool and water turned crystal clear!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    I stay open year round also. I would have left the pump running and added bleach every week or two or three as needed to maintain a chlorine level so algae wouldn't grow. During winter I turn off the SWG and test and add a gallon or two of bleach every few weeks to keep the FC around 10ppm.
    At this point I recommend removing the cover, opening the pool and SLAMing to kill the algae. It will be easier now while the water is colder. Here is how, Pool School - SLAM - Shock Level And Maintain
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    If you have blown out the lines, then yes the pump needs to be off. Running it dry can damage the pump.
    Even solid covers allow some water to get into the pool.
    I see from your previous post you closed the pool in November, which is probably too early in our mild climate. You want the water temperature consistently below 60 before you close to avoid algae growth. For more information on closing next year check out Pool School - Closing an In Ground Pool
    or this thread from 2007 - Closing an in ground pool
    While I didn't have a pool, I lived in Kennesaw for five years and don't think I would close a pool in that area if the pump equipment could be easily protected.
    Support the site
    Saturn94's Avatar
    Mar 2015
    Virginia
    496
    Quote Originally Posted by hotlanta View Post
    Hello
    Thanks
    I hear you. Our pool came with a mesh cover which made spring opening a lot of work. Some years ago I started covering the mesh cover with a tarp style cover and am much happier with the results.
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
    Jul 2012
    North Atlanta
    22
    Quote Originally Posted by Dr. Hops View Post
    Sent from my SM-T530NU using Tapatalk
    Hey Doc nice talking with you I'm right down the street in Woodstock
    Thanks everyone
    Hayward Chlorinator
