Results 1 to 9 of 9
Thread: Plastic strip between tile and concrete coping?
    Feb 2016
    Las Vegas, NV
    2
    Hello! Our pool is very close to being done and I need some feedback/advice! I spent a great deal of time planning my raised wall with the glass tile, and even when speaking with my builder we decided to upgrade to copper waterfalls because I did not like the look of the white plastic waterfalls. Well, they did the tile and concrete coping a couple days ago and I noticed this white strip of plastic along the sides and top...which I mistakenly thought was temporary. Today I found out that it's permanent! I'm so upset...my builder says that ALL pools have this and there's nothing I can do...there's no other option. I'm having a hard time believing this! I can't believe that after all that planning and upgrading the waterfalls specifically to NOT have white plastic on my wall...it now has white plastic all around it! Also, the concrete coping is going to be a dark gray, so that's going to make it stand out even more.
    Anyway...does anyone know...is this the only option? Is there anything I can about it? Can it be painted or even removed? I've scoured the internet trying to even see what this is called and some examples of pools with this and I can't find any.
    Any feedback is appreciated! Thanks!
    Jan 2016
    Mesa, Az
    541
    Re: Plastic strip between tile and concrete coping?
    Get some Krylon plastic paint in a rattle can, mask off the tile and coping and paint it to blend with either the tile, coping or just flat black to make it disappear. You'll still know it is there, but no one else will.
    Apr 2013
    Sacramento, CA
    2,769
    There are probably ways to do that wall without the joint looking like that. However, its done. The suggestion above is a good one so you might try that.
    Jan 2015
    las vegas
    92
    You can have them cut out the plastic strip, put backer rod in the gap between the pool shell and the decking. The grout companies make a flexible caulk that matches the grout colors, apply the caulk over the backer rod. Sika flex also makes products that can be used but they will not match your grout color.
    Jan 2016
    Mesa, Az
    541
    Quote Originally Posted by lasvegaspools View Post
    That will work but if you're not really skilled at caulking a large joint like that, it can turn into a real mess with the end result looking worse than the present condition.
    30,400
    Agreed but that should not be an owner issue. That's something for the PB and tile man to work out.
    I normally lean towards a builders side on pool disagreements but for him to say NOTHING else can be done fires me up. He should have that tacky looking strip taken down and the gap grouted with backer rod and poly sanded caulk as suggested above.
    Feb 2016
    Las Vegas, NV
    2
    Thank you everyone for the suggestions!! The guy that is coloring the concrete said he is going to color that plastic the same...so hopefully it'll blend in. That might last us awhile until maybe I can get someone to do a more detailed fix, which I'm not going to even bother asking our current pool guy to do. I don't have much faith that it'll get done right!
    Apr 2017
    Sacramento, CA
    45
    Hi there, we are getting ready to build our pool and I ran across this thread. I love your tile selections! Could you tell me what pool finish you selected to go with it and also could you tell me what is the color of the concrete you used for wall cap? Any completed pictures you would share? Any help would be greatly appreciated
    Tucker020's Avatar
    Mar 2016
    McGregor, Texas
    85
    I certainly could be wrong; but I wouldn't hold my breath on an answer. The OP has 2 posts since becoming a member of this forum; and they are both contained in this thread....which is almost a year and a half old.
    My Build Thread 16' X 33' Freeform 3.5' - 6' depth 8' Round Spa StoneScapes Midnight Blue Mini Pebble Noble Tile - Pietra Lavica (Lipari) Tile Oklahoma Flagstone Philips Hue Color LED's in Light Poles Hayward Tri-Star Hayward Sand Filter Hayward Navigator E-Command 4 control panel w/ remote 725 sqft washed aggregate decking
