Page 1 of 7 1234 ... LastLast
Results 1 to 20 of 128
Thread: Complete with Refill Am I ready to SLAM?
    kfpool's Avatar
    Jan 2016
    Port Orange, FL
    131
    First I want to say that the support here is outstanding! Thanks to everyone that has helped me along with my 1st pool.
    I Just want to reach out for confirmation. I drained approx 75% of my water, cleaned the pool of a LOT of gritty debris & have refilled. The water is now a clear yet green color.
    Test results from my lastest test
    FC - 1
    CC - 1
    TC - 2
    TA - 90
    CYA - 70
    PH - 7.7
    CH - 220
    Looks like I need to
    Add 17 oz Acid to lower the PH
    Add 640 oz of 8.25% bleach to get to the recommended shock level of 28 FC
    I am thinking adjust PH tonight, Retest tomorrow and start SLAM
    Am I on the right track?
    According to pool School, I need to keep the FC at 28 during the SLAM. My question is... how long for the FC levels to get down to normal?? I assume I just stop adding bleach until it drops to the desired level?
    Port Orange Florida
    In Ground Plaster Kidney
    36 x 18 - 16,000 Gallons. 3ft - 6ft
    Hayward C12002 Cartridge Filter, 1-1/2 HP Pump
    Jun 2014
    15,255
    Re: Complete with Refill, Ready to SALM
    kf, assuming your only issue is confirmed algae, then yes, you look to be correct. 28 is your SLAM FC level. So after you lower your pH, then "maintain" that higher FC until you pass ALL 3 SLAM criteria. Keep the pump on 24/7, and sweep every day as well. Only after passing all 3 SLAM criteria do you allow the FC to lower back to normal on its own. Hope this helps. Let us know if you have any more questions.
    kfpool's Avatar
    Jan 2016
    Port Orange, FL
    131
    Re: Complete with Refill Am I ready to SLAM?
    Thanks, I added the acid tonight and will verify the PH tomorrow evening. If it looks good I will begin the SLAM process tomorrow evening
    Port Orange Florida
    Aug 2014
    Northern IL
    4,615
    If you're not a penny-pincher, you could dump some a jug of chlorine in tonight. May not help, but it certainly won't hurt as long as you aren't on a tight budget.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    How long depends on how hardy your particular strain of algae is, how diligent you are about maintaining it at shock level, and how thoroughly you brush. Once the three criteria pass, then you just stop adding bleach. With cool water and winter sunlight, it might take a week or more for the FC levels to drop to your normal maintenance level. There's no way to predict it. You'll just have to test and see. Be aware that chlorine loss to sunlight is a percentage, not a fixed amount per day. Also be aware that it's safe to swim in it up to shock level for your CYA level. And remember that the pH test will read falsely high when FC is above 10, so don't try adjusting it until after the SLAM is complete and FC has dropped.
    kfpool's Avatar
    Jan 2016
    Port Orange, FL
    131
    Started SLAM - FC did not drop
    Started my SLAM after refilling. Raised FC to 28 at 7 pm last night, brushed the pool 2x and cleaned filter 3x. Water is cloudy & green. Checked FC this morning & FC had fallen to only 27. Cleaned the filter and raised FC to 31 since I will be away all day.
    Is it normal for FC to not drop?
    Test before slam
    FC - 1
    CC - 1
    TA - 80
    CYA - 70
    PH - 7.8
    CH - 175
    Port Orange Florida
    30,432
    No. Let's see what it does today but I supect there may have been a testing error. You hav your FC up where it needs to be so keep it there (as you are doing) and you should see daily imp[rovement in your water clarity.
    Watch your pump pressure and backwash when psi goes 25% above normal.
    kfpool's Avatar
    Jan 2016
    Port Orange, FL
    131
    My test this morning was at 7am. Just had my wife retest (11am). FC is 31
    Port Orange Florida
    Jun 2014
    15,255
    That's good KF. Stay at (or slightly above) 28. No need to go much higher. Simply "maintain" that FC SLAM FC 24/7 with pump running and continue your vigilant sweeping. Soon that cloudy green will transition to a cloudy blue before clearing. Oh, make sure to check any hiding spots for algae (i.e. light fixtures/niches). Be patient and let the bleach do it's job and you'll be fine.
    kfpool's Avatar
    Jan 2016
    Port Orange, FL
    131
    Thanks, forgive me for being a little uneasy. I expected the FC to drop more quickly
    Port Orange Florida
    kfpool's Avatar
    Jan 2016
    Port Orange, FL
    131
    OK, I have been keeping an eye on the pool all afternoon. FC did drop to 25 at my 2:00 test and I added 2 jugs of 6% which should have brought the FC to around 30. Tests at 5:00 and at 8:30 show no loss in FC with FC at 31 for both readings. It has been in the 80s and sunny here today & based on the other test results is probably responsible for the FC loss..It just does not seem correct that the FC level is not going down. The water is a cloudy green & the filter is always plugged with a greenish brown film. (a little sandy looking?) I failed to get a photo before the sun called it a night.
    Am I missing something?
    Port Orange Florida
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,197
    Is the pump running 24/7 and are you brushing the pool?
    Support the site
    kfpool's Avatar
    Jan 2016
    Port Orange, FL
    131
    Pump is running 24/7 & I am brushing every couple of hours. Filter usually plugs shortly after brushng. Could this simply be some sort of silt causing the cloudy water?
    Port Orange Florida
    May 2014
    Franklin, NC
    9,197
    Do you have any way to bypass the filter and just circulate the water without filtering?
    Support the site
    kfpool's Avatar
    Jan 2016
    Port Orange, FL
    131
    The only way I can accomplish that would be to pull the element out & run with the housing empty.
    Port Orange Florida
    kfpool's Avatar
    Jan 2016
    Port Orange, FL
    131
    Assuming you would reccommend that to ensure that the flow is as high as possible?
    Port Orange Florida
    May 2014
    Franklin, NC
    9,197
    I am looking for as much circulation of the chlorine while avoiding the possibility of the filter getting clogged and being damaged. I always like pools with multiport valves that allow a re-circulation mode to use that when the pool will be unattended to prevent what you are describing, the filter clogging.
    Support the site
    kfpool's Avatar
    Jan 2016
    Port Orange, FL
    131
    I know I probably need a larger filter, when I do that I will plumb in a bypass. I guess the question is... Do I need circulation more than filtration at this point?
    Port Orange Florida
    JoyfulNoise's Avatar
    May 2015
    13,254
    What was this pool filled with? Well or city water?
    Matt
  20. Back To Top    #20
    kfpool's Avatar
    Jan 2016
    Port Orange, FL
    131
    City water
    Port Orange Florida
