Thread: Replacement Spa Drain Covers
    Sep 2015
    Katy, TX
    1
    Hello,
    I have a spa drain cover that broke and I am trying to replace both of the covers. I am having trouble finding a replacement that will fit the existing opening. The diameter of the cover is 7 5/8in the screw holes are 7in apart.
    I am attaching a few pics of the spa, and the cover which has a part number from American products which was bought by Pentair it looks like.
    I would appreciate any help someone may be able to provide with a retrofit part suggestion.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Replacement Spa Drain Covers
    I think you are going to have a hard time finding one of those.. the covers now have to be an Anti-Entrapment Cover like this...
    AquaStar Low Profile Anti-Entrapment 8 inch Suction Outlet Cover with Vented Mud Frame, White
    Apr 2013
    Sacramento, CA
    2,769
    If you are good you can get these at an on line pool store. Most of the VGB anti entrapment replacement covers come with kits tor retrofit. You just have to figure out which one woks for your pool.
    A better solution is a pool store road trip. Spend a Saturday morning visiting pool stores with your cover and a diagram of your drain. See what they recommend and how the retrofit covers work for each one. It takes more time but its hands on and you can see what they look like out of the box.
