Thread: First time Spa testing
    May 2014
    Clarksburg, WV
    331
    So i've converted my neighbor to TFP and he just got a hottub and wants to try and use the same principles in it.
    I'm tying to help him and I'm telling him how i take care of my pool and to do that same for the hot tub. But i'm not sure if thats exactly true....is it?
    Should we shoot for the same 30cya - 5fc - 7.5ph like the pool? I know TA is super important in a hot tub. What should it be? I've read around 50.
    Any help would be appreciated....
    Thanks!
    24'x54" 15k AG round - Outback Genesis
    1 1/2hp Hayward Matrix 2 speed. Hayward 180T Sand Filter
    TF-100 Test Kit
    Pool School & TF-100
    How to SLAM
    Donldson's Avatar
    NW Ohio
    2,893
    Re: First time Spa testing
    Hi Kris. As you know a pool and hot tub are similar but different animals. So while it does mostly require the same things it does need to be adjusted a bit. As such there is a sticky about using chlorine in a hot tub, right here: How do I use Chlorine in my Spa (or pool)?
    There is also one for bromine if he decides to go that route instead: How do I use Bromine in my spa (or pool)?
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    What he said ∆
    Generally you want 50-70 TA, it should be low enough to prevent the pH rising from aeration from jets. That and clean your filters every few weeks.
    Intex 15'x48" AG metal frame pool (4,440 gal), Krystal Clear (1600) 14" sand filter, Taylor K2006 test kit, Intex Deluxe Maintenance Kit/vacuum (love it!), Intex Deluxe Skimmer, BBB.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    The how to use chlorine method works great. Been using it for over 2 years now and we are very happy with it. Bacteria grows faster in hot water and chlorine gets used faster. The key is to learn the tub's usage pattern. Keep testing FC after using the tub until FC holds and then add enough to stay above 0 until the next time you plan to test and add bleach again.
