Results 1 to 7 of 7
Thread: New Pool Project
    Jan 2016
    Mesa, Az
    541
    New Pool Project
    Planning has begun for a new pool project! The actual build won't begin until July, but it's never too soon to get the details hammered out.
    I'll begin with the site, the design, and an equipment list provided by the pool builder. This will be happening while I am living/working in another state, so getting the right people involved is even more critical than usual. The site is locked in , but feel free to comment on anything else!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Re: New Pool Project
    It looks great to me BigE
    Keep us posted as it comes along (whenever you can).
    Divin Dave,
    Jan 2016
    Mesa, Az
    541
    There are a few changes already. The bench wall and wok pots are being deleted as I want to look toward the wash, not the house. I think the wall will impede the view as well. I want to have returns on the spa-spill so the water doesn't spill out onto the deck. In lieu of the wok pots, I want the two pedestals moved to the spa-spill returns and instead of pots, a LED laminar jet on each pedestal. The rendering does not show the view fence and the sketch and rendering are 180 degrees turned from each other. Equipment list to follow.
    Jan 2016
    Mesa, Az
    541
    Pool equipment
    Automatic water leveler
    Hayward Ecostar VS pump
    Hayward 430 SF cart. filter
    1 aerator
    1 400 W clear light
    Automatic pool timer
    Paramount PV3 in-floor cleaning (22 heads)
    Mini-pebble finish
    Spa
    Hayward 400K heater - nat gas
    Hayward Tristar pump - 2HP
    9 jets
    Blower for bubbles
    Hayward clear spa light
    Pavers - Travertine
    Pool is 20'W x 30"L
    11' x 11' baja deck 18" deep
    3 - 4 - 5.5 Depth
    Spa is 6' x 8' interior dim. 3.5 feet deep
    App Vol <15K gal
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,755
    My take on the equipment...Keep in mind I'm not a Hayward guy but it still applies.
    Filter - Hayward makes a 525 sq ft model (C5030), Get the largest filter possible. It means less cleaning and better efficiency
    Light - There is no reason to install an incandescent light anymore. Go with at least 2 color LED lights in the pool and 1 or 2 ColorLogic lights in the reef area. You cant have enough light
    Timer - Look into an automation system, especially with a spa, color changing lights and multiple pumps...Well worth the investment
    In Floor Cleaning - Not worth the expense in my opinion. Use the savings for a robotic cleaner and automation
    No need for the dedicated spa pump, your 3HP main pump is sufficient to run the spa but not with 9 jets. You can get away with 6-7 jets with 3" plumbing to/from the spa. However, I would still HIGHLY recommend a second pump for your water features. I prefer variable speed pumps for this application because they allow you to fine tune the flow to your needs. If you want more than 7 spa jets, consider an additional booster pump (bring your total to 3).
    No need for a blower with a properly plumbed hartford loop in the spa
    Spa light - color LED as well
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Jan 2016
    Mesa, Az
    541
    Brian, Thanks for your feedback . . .
    Quote Originally Posted by bdavis466 View Post
    Pool builder uses Hayward exclusively. I don't have enough experience to have a preference. Reviews are pro and con for both Hayward and Pentair.
    I know size matters is a cartidge filter mantra around here. I'll look into the price difference. I'm already at least $5K over my expectation when designing this.
    Agree on the color changing LED lights, have to make the budget work with them. I'm surprised how much they cost over conventional.
    I'm not certain what he's referring to with automatic pool timer, something really basic like the built-in pump control menu or something more like Pro Logic
    I know in-floor isn't a favorite here but I won't be living there for two - three years and I cant have a rover all notted up and doing circles between visits by the maintenance person.
    I have no experience / expertise in this area so I'll defer to your knowledge in this area.
    Agree. see above in re: budget . . .
    ​Again, thanks for your input!
    spoonman's Avatar
    Jun 2016
    Peoria, AZ
    242
    Nice looking pool, BigEinAZ. I really like the raised sitting area for lounge chairs.
    14x28 IG Rounded Rectangle, 6" aqua tile, White plaster, Gray Acrylic deck, 4' Baja Step (18"), aerator jets, 3-step InterFab SS Ladder, Pentair Intelliflo VS Pump, Pentair TR100C Sand Filter, Stenner Econ E10T2A (chlorine), K-2006, Zodiac Baracuda G3 pool cleaner
