Thread: Aerator
    Oct 2015
    Orinda, California
    56
    Aerator
    Here is a picture of my Aerator. I think it is okay. Read a post from 2008 ish which gave instructions on how to build as I don't have a waterfall, etc.
    I drilled four holes in the cap. My question is should water be coming out from this? I was thinking it would just be air.
    28,000 gallon IG pool, plaster, built approx. 1970.
    1 1/2 " plumbing. Pentair, Intelliflo 3 hp variable speed.
    Crystal Water cartridge filter system, model #425
    Dolphin Deluxe 4,
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: Aerator
    Aeration is just about increasing the air to water contact area. You just want to spray water up above the surface of the pool to increase that contact area. It can be a fountain, waterfall, spill over or just turning the return eyeballs so that the return water breaks the surface, anything that increases that contact area will increase aeration.
    chiefwej
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: Aerator
    Yes, that is how it should work, shooting water from the pool return into the air. Looks good!
