Thread: Hi/Lo relay switch for WhisperfloXF 3hp
    Jaxcmc's Avatar
    Jan 2016
    Macclenny Florida
    31
    I have a 2 speed Pentiar WhisperfloXF 3 Hp. It did not come with a switch to change from Lo to High. Any ideas on what types of external switch/relay to get???
    Mar 2015
    Sugar Land , TX
    424
    Re: Hi/Lo relay switch for WhisperfloXF 3hp
    found this:
    Some dual speed pumps have a toggle switch in the back of the motor to change speeds manually, but many do not. Generally you would need to tie this dual speed pump into one of our dual speed pump timers/controllers. One of the more popular models is the Digital PE153 series. This timer has 3 functions: one to turn the pump on and off, a second auxiliary to switch from high speed to low speed, and then a third for any other piece of pool equipment. You may view these controllers through the following link: Intermatic Timers
    8500 gallon IG Pebble Sheen with Spa. 3hp Pentair VS Intelliflo ( pool ), 3/4 hp WhisperFlo ( water feature ),Pentair Racer, 400K Pentair heater, Pentair 500sqft Cartridge filter, EasyTouch 8, Stenner 45mp2 15gallon wired to ET8
    Jaxcmc's Avatar
    Jan 2016
    Macclenny Florida
    31
    Geez, that was easy. Headed to look at the timer/controllers now. Thanks!!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    Right. If a timer is going to be involved, it takes the place of the switch.
    Divin Dave,
    Jaxcmc's Avatar
    Jan 2016
    Macclenny Florida
    31
    Quote Originally Posted by rphpool View Post
    found this:
    After reading your instructions, this is exactly what I needed...thanks for your help!!!!
    47k, 40x20 IG plaster,SWG, 24 jets, 3HP Pentair Whisperflo 2 speed,Hayward Pro Series Sand Filter36" Tank S360T2 TF-100
