Thread: return part
    Oct 2015
    Orinda, California
    56
    return part
    Hello All - not sure where to post my question. I'm trying to aerate my pool, just raise PH. I'd like to input PVC pipe in my return thread. My problem is I can't twist off a unnecessary part as I think it is glued. I believe I have a 1.5" or 2.0" female thread that screws into a return. I will post a pic and hopefully the forum will steer me in the right direction where I can purchase. Thanks.
    28,000 gallon IG pool, plaster, built approx. 1970.
    1 1/2 " plumbing. Pentair, Intelliflo 3 hp variable speed.
    Crystal Water cartridge filter system, model #425
    Dolphin Deluxe 4,
    Oct 2015
    Orinda, California
    56
    Re: return part
    adding two more pics
    Dolphin Deluxe 4,
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: return part
    Hi,
    those are just bushings / adapters to reduce the pipe size. There is nothing special about them. They are regular PVC and you should be able to find them at big box store, plumbing supplies or anywhere else with a larget selection of PVC pipe and fittings.
    Divin Dave,
    Oct 2015
    Orinda, California
    56
    Re: return part
    Divin Dave - thanks. You think I could take to part to Home Depot and get part? better HD than pool store. Thanks
    Dolphin Deluxe 4,
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: return part
    Its a couple different parts that will have to fit together and yeah, if you take it with you, Im sure you can get what you need. I dont know about your HD, but mine doesnt have a very good selection of PVC fittings. Lowes is better for this type of thing IMO.
    I seriously doubt the pool store would be of any help at all on this.
    Divin Dave,
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: return part
    I discovered that I could friction-fit PVC into the return eyeballs on my pool. Now I can get creative with elbows and tees and 45's to direct the flow better.
