Thread: Problem Pool
    Jan 2016
    San Antonio
    7
    Problem Pool
    We recently purchased a home with a large pool. The house was discounted due to issues with the pool. The pool was built in the late sixties, and repaired on the cheap several times. We took on the adventure of repairing this pool. There are multiple cracks in the plaster that have been repaired. The pool light has been plastered over and the main drain has been covered over. The leak is located at the bottom of the last step and there is water coming back out of the crack. This site has been a great resource as to what to look for. We plan to do decking, plumbing, and coping ourselves.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,637
    Re: Problem Pool
    HI! What an adventure you will be on! We would LOVE to see the pool and work!
    So neat you got a deal because of the pool that you can fix!
    Start a thread in "under cons." so we can follow along and help!
    Kim
    Jun 2014
    15,249
    Re: Problem Pool
    Hey neighbor. Welcome to the forum. Lots of locals here on TFP. Also, don't forget to update your signature with all of your pool info for later. It's helps everyone to help answer any questions you may have. Good luck on your project. Enjoy our 80-degree day tomorrow. Who said we're in Jan/Feb?
    Jan 2016
    San Antonio
    7
    Re: Problem Pool
    I agree with that 70s who would of thought. Our bi polar weather hear in San Antonio will change.
    Casey's Avatar
    SW PA
    10,457
    Re: Problem Pool
    Welcome. Hope you stick around and add your repair build to our Construction forum so we can help you and watch as you renovate your pool.
