Thread: CSI question
    Capstone's Avatar
    Jul 2015
    Alabama
    10
    CSI question
    I am confused about CSI and if I need to do anything. I tested my pool today for the first time using the Taylor kit. The results were as follows:
    FC = 5.8 ppm
    CC = 0 ppm
    pH = 7.6
    TA = 120 ppm
    CH = 120 ppm
    CYA = 58 ppm
    With a pool temp of 45 degrees F; I calculated a CSI of -0.4
    Is this an issue?
    Thanks.
    40,000 gal vinyl saltwater; Pentair Intellichlor, Pentair Intellibrite 5g; Pentair cartridge filter
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,758
    Re: CSI question
    Low CSI values can be dismissed with a vinyl liner pool. The bigger issue to be concerned with is high CSI values (> +0.6= Scale) and pH below 7 ( due to possible copper damage (if a heater or copper piping is present).
    Seasonal drops in temperature and subsequent drops in CSI are expected and of relatively little concern.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Aug 2014
    Northern IL
    4,615
    Re: CSI question
    Also, if you would like to save on reagents, you can use a 10ml sample for FC/CC and multiply the drops by 0.5. The directions are on the inner lid of your testkit box.
    Capstone's Avatar
    Jul 2015
    Alabama
    10
    Re: CSI question
    Thanks.
