Results 1 to 10 of 10
Thread: New equipment in an old construction
    hkgustav's Avatar
    Jan 2016
    San Fulgencio
    5
    New motor and filter was necessary for my 20 years old pool. I had this house and the pool for 2,5 year now - but with water in the pool, only for 2 years - as I repaired the tile joints first...
    Now the filter was too old to get spare parts - the top was broken, the motor the same > too old and noisy..
    But underneath my filter it was a hole in the cement, with only gravel and stones
    . And I do not understand why ???
    Can anybody give a good reason for this solution ?
    See picture....
    It can also be said that the old filter had come out of level, and had already made some problems conc. broken pipes...
    Killer95Stang's Avatar
    Sunny SoCal
    592
    Re: New equipment in an old construction
    Concrete pad was probably pretty thin, so the vibrations might have cracked it over time. A new concrete pad is a pretty easy project and can be done very cheaply. My suggestion, watch a few youtube videos and make yourself a new pad. Then you can start from scratch with the new equipment.
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    hkgustav's Avatar
    Jan 2016
    San Fulgencio
    5
    Quote Originally Posted by Killer95Stang View Post
    Well - maybe so....
    But it should not be so much vibrations on the filter....
    The motor was still on its own place - with no crack of the concrete pad...... And the motor should have more vibrations (??)
    BUT YOUR ADVICE, AS WELL AS I UNDERSTAND, IS THAT THE FILTER SHOULD STAND CONCRETE PAD ?????
    Jun 2014
    15,208
    In addition, if you're not comfortable with doing your own concrete pad, they make pre-fab pads made of composite material that will support a pump and filter. You can see mine in the "My pool" link from my sig. Just a thought. Regardless, that original set-up of yours looked extremely thin. Not surprised it finally gave out. Best of luck to you.
    hkgustav's Avatar
    Jan 2016
    San Fulgencio
    5
    Well, I followed your recommendations ... I bought some very thick tiles / concrete slabs and filled the hole with concrete - while I also leveled the former concrete. So now I am going to assemble a new filter and motor > and trying to get all the tubes to fit .. Thank you for advice ...IMG_20160204_194345.jpg
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,579
    Nice work! That looks so much better! Good luck on the equipment and such! It will all be worth it when you are done.
    Kim
    hkgustav's Avatar
    Jan 2016
    San Fulgencio
    5
    Everthing finished - except the pool isn't fill up yet. 60.000 l takes time with low pressure and thin tube...
    Every 90 degrees is made by 2x 45 degrees... I hate "hard" 90 degrees.
    New ground, new motor, new sand filter with new sand, new shuttlevalve, new water taps and new pipes.
    Hope everything works when the water is filled up.
    Jul 2012
    Tallahassee, FL
    30,579
    Lets hope it works as good as it looks! When do you think it will be full? Have you been adding any bleach while it fills?
    Kim
    hkgustav's Avatar
    Jan 2016
    San Fulgencio
    5
    Nearly everything works fine.... Except for the nozzles (/jets?) nearly blowing out, and the pressure became a little bit too high. I think the new pump was a "little bit" stronger than the old one, (the old one has no readable text). I take away the the nozzles > if you think theese are nessesary, I can make the outlet hole in it bigger....
    And the new motor became very warm > more than 60 celcius degrees ... I made a complaint to the distributer, but everything was ok... Then I found out the the voltage in my house was 252 volt (>up to 263 v i has mesured!) . Now i'm awaiting that the electricity-company will do something before I start using it... I live in Spain - Manjana manjana........
    Isaac-1's Avatar
    SW Louisiana
    6,711
    If they don't ask an electrician there about getting a buck/boost transformer
