Results 1 to 13 of 13
Thread: DE Filter Grid Replacement
    Aug 2013
    Dallas, Texas
    85
    Question DE Filter Grid Replacement
    I have a Pentair FSN 48 Filter DE system and have a tear in one of my filter grids, the rest seem ok, I was wondering if I should be replacing the entire set at the same time or it should not really matter.
    We bought the house 3 years ago so the filters are atleast 3+ years old. Local pool store said its best to replace all filter due to the pressure in the system and how the new vs old grids would work - not sure I agree with the stores logic.
    17500 Gallons, IG, Plaster, DE Filter, Built 1997, No Spa, Polaris 280
    Jun 2011
    Long Beach, CA
    2,788
    Re: DE Filter Grid Replacement
    Did you accidentally tear the grid or was it torn from wear and tear? If it is from wear and tear then I would replace all the grids, but if you tore it, then I would inspect the condition of the other grids.
    Follow this advice for inspecting and cleaning the grids, DE Filter Cleaning Tutorial.
    Aug 2013
    Dallas, Texas
    85
    I had DE coming back in the pool so checked the filter and found the maniford was cracked in many places so purchased a new one, then I checked the grids and followed the tutorial and found 1 grid had a tear which I beleive is from wear.
    Jun 2011
    Long Beach, CA
    2,788
    I would buy a new set of grids in your case.
    Aug 2013
    Dallas, Texas
    85
    thanks for the advise - will pull the trigger on a new set.
    Aug 2013
    Dallas, Texas
    85
    Looking around the web, I see pleatco brand and unicel - anyone now if there is a difference in quality? the pleatco brand is cheap for buy.
    Jun 2011
    Long Beach, CA
    2,788
    From what I searched here at TFP it seems that the Pleatco grids are fine. The Unicel are OEM grids for Pentair.
    Mar 2015
    Houston, Texas
    14
    If the manifold was cracked, make sure the GPM output of your pump matches the designed flow rate of your filter. Unless the filter is fairly old, the manifold typically only breaks for one of two reasons- to much flow from the pump or excessively high pressure (not back washing often enough).
    Aug 2013
    Dallas, Texas
    85
    Thanks MHarvey86 - I think the fault is all mine - I did very few backwashes last year and paying the price.
    Quote Originally Posted by onedah View Post
    I did the Unicell, thya have been fine. I believe there is a You Tube video on the grid replacement according to one punter on this site. I took a bunch of photos during the swap out, but if there is a vid then that would be better.
    Aug 2013
    Dallas, Texas
    85
    Update on Progress:
    - Purchased a replacment manifold due to crack
    - Purchased replacement filter grids, I went for the pleatco grids which look as good as the Unicell and saved around $35 on all 8 grids
    - Rotated wheels on Paloris cleaner (280) as 1 wheel had broken teeth
    - Overall pool is now crystal clear - sand that was in the pool as been sucked up and back in the filter
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Nice work!
    I am a big fan of my Pleatco filter cartridges.
    Jun 2014
    Glendora, CA
    61
    I am having the same issue. I cleaned the filter and noticed the cracked on the manifold (patched it with epoxy). Some filters have holes but I continued to reuse them. I noticed the pool got cloudy and DE powder on the pool surface. Just ordered new filter and manifold.
    Does the DE Powder damage the pool surface, etc?
