Results 1 to 16 of 16
Thread: Rising PH
    Oct 2015
    Orinda, California
    56
    Rising PH
    My PH has been rising for the past six months and I can't determine why. Get's up to 8.2 and I add acid and goes to 7.7 For the past 3 years has held steady at 7.8
    test results have been as follows:
    fc: 10
    cc: 0
    ta 100
    ch 320
    cya 70
    ph 7.7 - 8.2
    any help appreciated. TJ
    28,000 gallon IG pool, plaster, built approx. 1970.
    1 1/2 " plumbing. Pentair, Intelliflo 3 hp variable speed.
    Crystal Water cartridge filter system, model #425
    Dolphin Deluxe 4,
    Aug 2014
    Northern IL
    4,615
    Re: Rising PH
    Have you tried lowering your TA?
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,758
    Re: Rising PH
    Thats not surprise since your TA is on the high side. Consider your TA as a pH buffer, the higher it is, the more tendency your pH will have to want to rise higher and faster. Lowering your TA to 60 should drastically reduce the speed of the pH rise and could ultimately hold the it at bay since a pH of 7.8 and a TA of 60 is nearing being at equilibrium with the carbon dioxide content in the atmosphere (carbon dioxide outgassing being the primary driver of pH rise).
    Any form of aeration also contributes to pH rise so limiting that and lower TA values would be in your best benefit.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Aug 2014
    Northern IL
    4,615
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: Rising PH
    +1 to all of the above.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Rising PH
    100 TA will be the primary reason.
    Essential Links:
    Re: Rising PH
    It's odd that it was steady for three years and suddenly there's unexpected ph rise. Did anything change recently? Maybe a replaster or add salt system?
    What are you doing for chlorine?
    Support the site
    Oct 2015
    Orinda, California
    56
    Re: Rising PH
    8.25 Bleach.
    I bought a tf-100 test kit late last year. All of my test results were good except cya -125 and ta -70. I thought it should be been 80 and 120. I targeted 100, in the middle. Also the pool store was performing test for previous 3 years and also reported TA @ 100. OH Boy. I should lower to around 70 and the ph should behave. thanks to all.
    Dolphin Deluxe 4,
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,758
    Re: Rising PH
    That is exactly what happened then. The recommended TA value of 80-120 is not correct. There is no reason to raise the TA unless it falls below 50-60, the pH falls (very uncommon in most cases) or becomes erratic.
    -Brian-
    POOL BUILD
    Oct 2015
    Orinda, California
    56
    PH ?
    My PH keeps rising because my TA is ~ 100. I installed my home made aerator yesterday. Should raise my PH without raising TA Lowered PH to 7.0 So far my PH has not moved higher from 7.0 I wait for PH to rise to 7.5 then lower again until my TA is ~ 70. My question is when I stop using the aerator what will happen? I stop when PH is 7.5 and TA IS ~ 70. I think the TA will not go higher and same goes with my PH. (7.5) I'm concerned when I stop using aerator my TA will rise. Hopefully I am making sense to the forum. TJ
    Dolphin Deluxe 4,
    Jun 2014
    15,221
    Re: PH ?
    Every pool is different, but eventually they should both settle and find a "happy place" for your pool to where you won't have to do as much to maintain. For some folks, pH levels-off in the mid-7s with a TA at 70, other take TA down to 50-60 or so before pH stabilizes. It's a bit of a cat & mouse game for a while.
    30,431
    Re: Rising PH
    Please do not post different threads for your subject. Even if they're a bit different keep them together. I have merged your latest post
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,758
    Re: PH ?
    Quote Originally Posted by TJTJ View Post
    The purpose of aerating is to get the pH to rise quickly when you are aggressively trying to lower the TA. If speed is not a concern, drop the pH to 7 and add acid when it reaches 7.4 (no aeration) to lower it back down to 7. This will no doubt be a slow process but if you aren't in a hurry, why rush?
    -Brian-
    POOL BUILD
    JoyfulNoise's Avatar
    May 2015
    13,247
    Re: Rising PH
    Your TA will not rise due to lack of aeration. Only your pH rises as a result of aeration. Acid lowers both pH and TA.
    TA only increases when you add a source of alkalinity such as baking soda (sodium bicarbonate) or soda ash (sodium carbonate). Also, your fill water will add TA depending on the source. You can easily measure the TA of your fill water to see if it is a significant source of alkalinity.
    Matt
    Oct 2015
    Orinda, California
    56
    Re: Rising PH
    I have been testing my PH twice a day, always reads the same ~ 6.9 to 7.0
    I always drop 5 of the PH regents. TA is always ~90 PH just doesn't want to go higher for some reason. Can't figure out...
    I made my aerator and inserted into my return, where the air is pushed out into the pool. Is this also the jet? Did I insert the aerator in the proper place? thanks, TJ
    Dolphin Deluxe 4,
    Jun 2014
    15,221
    Re: Rising PH
    Maybe that's just not enough aeration for that size pool. From the pic, it doesn't appear to really stir things up very much to raise your pH. Here's a couple more examples:
    Smoking hot pool water
    Best Method to Aerate
    On a side note ... your water looks great.
