Thread: Aquarite 240V power question
    Jan 2015
    Anthem, AZ
    188
    Reading the manual the aquarite controller has 4 lugs for power, and in 240V you should use 1 and 4 for your load lines, and a jumper between 2-3. Can someone tell me what this jumper looks like? I purchased a used system and I'm only seeing the 4 screws, and 2 pieces of metal backing behind them that don't look like jumpers to me. They look flat and bend over the terminal input with a little hole. I'm thinking I don't have a jumper? Or these 2 are the jumpers and I have to move them.
    19K IG Pebbletec with attached spa. 60sqft Cartridge filter, Intelliflow VS, 399k BTU Gas Heater, Pentair IC40. Phoenix, AZ, full sun.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Aquarite 240V power question
    Post a pic. Jumper can be many things. Some mfg make a special use jumper and other (most) times people just use a section of the wire they are using bent to a U shape to go from one to the other.
    Jan 2015
    Anthem, AZ
    188
    actually it is the jumper, it looks like the previous user had it set up for 110v. its bent up over the terminal input so you can't insert a wire. i moved it to the correct position for 240v.
    now to figure out the 3hp relay wiring on the aqualink RS and how to get some more room on this panel. i've added a lot since i bought this home
    DFW, TX
    24,497
    Good deal. No help on the full panel, I am right there with you on that.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    If you aren't sure just put a piece of wire there to make the jump. It is hard to recognize if you don't quite know what it looks like.
    Factory Warranty Station for:
