Results 1 to 13 of 13
Thread: Labeling Suggestions?
    Jul 2015
    Bergen County, NJ
    113
    It seems like every year I have to get out to the pool pad with my Permanent marker and write over the faded markings from last year on the PVC pipes. Can anyone suggest a more permanent and professional looking way to label PVC? I'm looking for a label that can survive in direct sunlight as well as make it through the harsh Northeast winters.
    53K Gallon Plaster in-ground with ALL Hayward equipment including Omnilogic Automation, Phantom Turbo Cleaner, SwimClear Cartridge Filter, Heater, Dual T-15 Salt cells. TF-100 Test Kit w/Speedstir.
    38,547
    Re: Labeling Suggestions?
    I wonder of you could just spray a clear coat over the marker labels?
    Jul 2015
    Bergen County, NJ
    113
    I wasn't too clear on my initial post, but I haven't used any form of labels so far. Just hand-written directly on white PVC with a Permanent marker. So I'm looking for a suggestions on a label maker that can generate a good weather-proof label.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    There's an idea. A trip to Lowe's paint section ought to give you a selection of clear UV resistant coatings.
    38,547
    I think a label maker is going to fade to. And I was referring to you covering the marker with some clear coat.
    Jun 2014
    15,298
    Adhesive labels have worked for me so far, but if they didn't, perhaps I would consider attaching a small metal tag to each PVC line. Almost like a small dog tag or something?
    Jul 2015
    Charter Oak, California
    273
    I'm a civilian employee of a SoCal police department and work primarily as an upholsterer. However, part of my duties include cutting the vinyl letters, decals and numbers that are placed on police vehicles to identify them from the air. We print or cut various vinyl decals and signs as well. If you can find a small local business that prints or cuts vinyl letters for signs from adhesive backed vinyl goods, they should be able to cut out the letters/wording to to your specifications (i.e. Size, color, specific wording) to enable you identify your rigid plumbing lines for years to come. (Everything dealing with the police has some kind of vinyl decal affixed to it so everyone knows what to do.) Most vinyls will last 5 - 7 years as long as they are applied correctly. It's the same vinyl used to wrap vehicles with advertising or special designs. If you google vinyl plotters or vinyl cutters, there are even some relatively inexpensive machines to purchase for home use. Software that comes with the plotter allows you to use your laptop or desktop computer select font, size and shape. The adhesive backed vinyl comes in sheets or small rolls in a variety of colors. Hope this helps.
    Bob (AKA Schnozz)
    12 x 24 x 52 Intex Ultra Frame AGP, 8600 Gal; Pentair 2HP/2SP 150sqft Cartridge Filter; Hayward Through Wall Skimmer; Intex Automatic Cleaner (Fantastic); K-2006 Test Kit; Start-up 07/30/2015. First Time Pool Owner in SoCal.
    Aug 2014
    Northern IL
    4,615
    I am a librarian and we have to use special pens/markers/etc. Try looking for sharpie eXtreme.
    Here's a link: Sharpie Extreme | SharpieUSAStore
    mikespoolfl's Avatar
    Mar 2011
    Florida
    179
    I use a brother P-touch label maker with inch clear laminated tape. It’s been on my PVC pipes for about 5 years and still looks good.
    Screen enclosed 17K gal 16x30 IG with Diamond Brite finish, elevated 4 jet spa with spill over, Twin dolphin fountain, Hayward Ecostar pump[ Pentair intelliflo VS, Filter Sta rite Posi-Flo PTM 100, Aqua Cal heat pump, Tiger Shark QC robotic cleaner.
    Stenner peristaltic pump model 45MPHP10, 15 gal storage tank. TF 100 with Speed Stir.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    A&A makes a set of labels printed on vinyl. You can find them at several online pool supply outlets for less than 10 bucks.
    Just google "A&A pool equipment labels"
    chiefwej
    Oct 2015
    Katy/Texas
    411
    Amazon has a set for $11.50
    In ground, 14,000 gallon, white plaster, unheated, stone waterfall, DE Filter, Rainbow 320 Cl, Polaris 3900, FloVis flow meter, F100 test kit, Circupool RJ30+ SWG, Circupool VJ1/Speck Badu EcoM3V variable speed pump.
    Jul 2015
    Bergen County, NJ
    113
    Thanks for all the suggestions folks. The A&A labels are a great start and should cover about 80% of what I need. I did some research for some of the more customized labels that I'm going to need and came up with the Dymo IND vinyl labels which claim to resist moisture, extreme temperatures, UV light, oil, and chemicals.
    Here's a link to the labels:
    http://www.dymo.com/en-US/view-all-l...-labels-1-2-in
    and a label printer that work with it (under $40 at Amazon):
    http://www.dymo.com/en-US/label-make...wy-label-maker
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    A&A has several different sets that range from about $7 - $25. You should be able to find one that would meet all your needs.
    My pool builder left me a set, included with the pool build and at no extra charge.��
    I don't think I want to spend $75 or so on a machine and tape for labeling my pool equipment. A $2 sharpie or $10 for a sheet of labels is about my limit.
    chiefwej
