Thread: Over sized pumps
    Oct 2015
    Katy/Texas
    411
    Over sized pumps
    Today I installed a FloVis flow meter at the pump discharge.
    85 GPM @ 12.5 psig. At that flow rate my pool turns over in less than 3 hours.
    The motor is rated at 3 HP.
    Its safe to say that this pump is over sized. I see a two speed pump in my future.
    In ground, 14,000 gallon, white plaster, unheated, stone waterfall, DE Filter, Rainbow 320 Cl, Polaris 3900, FloVis flow meter, F100 test kit, Circupool RJ30+ SWG, Circupool VJ1/Speck Badu EcoM3V variable speed pump.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Over sized pumps
    Certainly over sized for filtering and circulation but it may not be over sized for the waterfall although 85 GPM is very low for a 3 HP pump. What is the pump make/model and do you have 1.5" plumbing?
    Mark
    Oct 2015
    Katy/Texas
    411
    2" piping. I'm not able to read any info off of the pump itself, all of the info has been weathered away.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Then how do you know it is a 3 HP pump? Does it say SPL anywhere near the 3 HP rating?
    Mark
    Oct 2015
    Katy/Texas
    411
    It has a 3 HP motor.
    mas985's Avatar
    Pleasanton, CA
    11,741
    So there is still a label on the motor? Does the motor label say SPL anywhere or is there a service factor listed?
    Mark
