Results 1 to 12 of 12
Thread: LSI vs Poolmath
    Dec 2015
    arlington, tx
    100
    LSI vs Poolmath
    my chemistry numbers are:
    FC 6.0
    pH 7.7
    TA 90
    CH 250
    CYA 30
    water temp 46
    no borates.
    using PoolMath the saturation index is -0.18. using the Langelier formula the saturation index is approximately -0.05. i calculated LSI using Taylor's Water Balance Calculator wheel that came with my K-2006 test kit.
    why is PoolMath's saturation index so different from LSI's?
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Re: why are PoolMath and Langelier saturation index numbers different?
    This is kinda confusing for me, but there are a couple threads here
    http://www.troublefreepool.com/archive/index.php/t-75058.html
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    Aug 2014
    Shallotte, NC
    693
    Put very simply, they are two different formulas. PoolMath uses the CSI....
    http://www.aquaticsintl.com/water-qu...-real-csi.aspx
    I fear this is headed into "The Deep End."
    Mod Squad pooldv's Avatar
    DFW, TX
    24,492
    Do you have the water temp factored in both?
    More here, Langelier and Calcite Saturation Indices (LSI and CSI)
    JoyfulNoise's Avatar
    May 2015
    13,204
    Read the links posted above for the detailed discussion. Essentially the pool industry modified the original LSI factor to try to make it work for pool water but it, the LSI, was never intended for open water systems like pools. The CSI was developed to specifically address open water bodies (like pools and spas) and comes much closer to actually predicting scale and corrosion than the LSI does.
    Also, remember that these indices simply give you a measure of how over-saturated or under-saturated your pool water is with respect to calcium carbonate concentration. The CSI will tell you if you are in an unbalanced state but it tells you nothing about the rate of plaster corrosion or the speed of scale formation.
    Matt
    30,420
    Re: LSI vs Poolmath
    Marcion333,
    This is of little interest to almost everyone on this forum. Appropriately, I have moved it to the deep end.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: LSI vs Poolmath
    Also Marcion, in many cases your CSI will be fine with the specific guidelines we suggest using. There are Caveats as with most things, but that's generally true. As said, LSI is more useful for other applications, and we use it extensively in my industry. CSI is also used and we rely on both for making lots of important and often critical decisions. CSI works well for pools since CaCo3 is by far our greatest concern. Typically, the other constituents don't reach levels of concern in most pools most of the time, but it's interesting stuff if you like delving into such things.
    Essential Links:
    Jul 2011
    Arizona & California
    803
    Re: LSI vs Poolmath
    As indicated above, while the CSI may be a more recent upgrade, there is not a lot of difference between the LSI and CSI, as both are calculated similarly. Neither Index is absolute on predicting what will happen in a plaster pool.
    Also, in terms balancing pool water, there is not a lot of difference between a -0.05 and -0.18. Both numbers are well within the "balanced" range.
    Both formulas provide a good idea of whether the pool water is within the balanced range or not.
    Dec 2015
    arlington, tx
    100
    Re: LSI vs Poolmath
    i thank everyone who appreciated my interest in trying to understand this issue and replied, and also thanks for the links.
    as cody in the Dual Survival series said, "Knowledge is power, and its very lightweight."
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: LSI vs Poolmath
    No problem, that's what we come here for, so it's good to hear you're enjoying the forum.
    Essential Links:
    DFW, TX
    24,492
    Re: LSI vs Poolmath
    LOL! Knowledge is lightweight. Never heard that before, I like it.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: LSI vs Poolmath
    Quote Originally Posted by pooldv View Post
    Ours especially!
    Essential Links:
