Results 1 to 10 of 10
Thread: Best way to fix a few cracked intex polls
    Jul 2013
    Long Island, NY
    534
    How would you fix these polls so they will 'hold up' throughout the rest of the winter and all summer. My idea was to use gorilla tape and just tape them. Would you think duct tape would work better? Thoughts? Thanks guys. The first pic is looking under the poll and the second pic is looking straight ahead at the poll.
    Gallons: 5000 Gallons
    Pool: 15' Saltwater 5000
    Filter: Pentair 1 HP Optiflow Pump w/ Clean & Clear 75Sq Ft Cartridge Filter
    SWG: Intex CS8110
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Re: Best way to fix a few cracked intex polls
    I would just get new metal pieces. I saw some on e bay, but intex has them also $5.
    http://www.intexcorp.com/store/above...lacement-parts
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    Jul 2013
    Long Island, NY
    534
    Do you think its possible to do that without taking the pool down?
    SWG: Intex CS8110
    banditig's Avatar
    Sep 2015
    Ohio
    466
    You probably have to drain most all of it. If you have a few people to help you might get by with more but try lifting first.
    Piper Mike's Avatar
    Jan 2014
    Bartlesville, OK
    200
    You will need to drain it. You can find the polls pretty cheap on Amazon too. I notice you have a saltwater generator. This has been my worry about getting one as too many people that have one says it causes the polls to rust. Sorry about this happening.
    Intex ultra frame 26'x52" above ground pool
    Intex ultra 18'x46" above ground pool retired
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,570
    I would not trust those. Time to replace
    Kim
    Jul 2013
    Long Island, NY
    534
    I need the pool to make it through this summer, then I will be getting a real above ground next summer. I'm wondering if there is anything I can do. Maybe replace with some PVC piping? I don't want to replace the polls. They are like $9 each and I need probably 10 replaced. With tax its like $100
    SWG: Intex CS8110
    Jul 2012
    Tallahassee, FL
    30,570
    Rich I have to ask..............will there be any children in the pool? PLEASE do NOT allow them in the pool like it is now
    I do not know if pvc could replace the poles.
    Kim
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,410
    Those very rusty poles are all that is holding your pool up. That photo on the left shows the underside of the pole is gone. There is nothing for that button to snap onto, which is what holds those poles together. When you get kids in there splashing around the pool will move and flex, that is what it is designed to do. Without the latching mechanism intact the poles will separate. Since you have 10 poles in roughly the same shape it is very likely the pool will collapse. Each gallon of water weighs about 8lbs. At 3500 gallons that is 28000lbs of water that will come rushing out. The weight of the water is also why using pvc won't work. Your best bet would be to watch for ads on sites like Craig's List and try to find replacement parts from someone selling the same size pool.
    Love TFP? Become a
    TFP Supporter!
    Jul 2012
    Tallahassee, FL
    30,570
    I am closing this thread as there is nothing left to add. This pool as it stands is unsafe for use.
    Kim
