Thread: Re-plaster needed, or is it just cosmetic?
    Jan 2016
    Lancaster
    1
    Question Re-plaster needed, or is it just cosmetic?
    Hello,
    I'm new to the forum but I've been reading posts for a couple years now - thanks to all for letting me eavesdrop.
    I have a question: Is my pool's bad plaster is a factor in having to dump tons of chlorine/chemicals in to try to control black algae? And, should paint/replaster the thing to save chemicals and hassle on trying to control that black algae?
    I have to confess my pool has been a bit of a headache for me and I've actually been contemplating turning it into a sunken-patio-thing or decking over it or just ripping it out and filling it in! It's an oddly-wavy-shaped 15x40 pool, with a 9-foot deep end. I've been battling black algae and green algae on the walls ever since I filled it two years ago. Even adding silver solutions and raising the chlorine really high (and brushing a lot, and rinsing the DE filter over and over) don't resolve the issue in a very satisfactory way. The water gets clear but the walls have a persistent presence of the black algae growing like a dotted spiderweb of evil.
    The pool is probably 30 years old and may have had a previous re-plastering job done long ago. It sat empty for about a year in 2013. The current plaster is pretty bad, which I suspect is a wonderful host for the black algae to get in deep. A while back I drained out the attached spa which has the worst problems on the plaster. I took the back end of a claw hammer and knocked around a little bit on the small chunks of partly delaminated plaster. The black algae was growing *under* the plaster, too. Not having the time to attempt whacking away at the whole spa and starting a replaster right then and there I just did a quick acid-wash/brushing and refilled it. That has had zero effect on the native black algae population.
    Thoughts? Is a highly pitted / delaminated plaster pool going to be an algae nightmare until I fix the plaster, or is the plaster more of a cosmetic issue and my problem is mainly a chemical one?
    Thanks!
    15x40 pool, kidney/wavy
    ~25,000 gallons (guessing)
    Southern California
    30,431
    Re: Re-plaster needed, or is it just cosmetic?
    Welcome to the forum.
    The short answer is yes. Algae, especially black algae, develops in nooks and crannies where chlorine can't get to it. A badly chipped surface combined with some long term under-chlorination and lack of brushing, is a great recipe for algae.
    From your description it sounds like you will be in a constant struggle until you replaster the pool. You can likely control it with chemistry (PROPER chemistry) but you may never defeat it if your plaster is in the shape I think you are describing
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,584
    HI and what he ^^^^ said!
    I would look into getting new plaster AND a good test kit. With these two things we can help you LOVE your pool!
    Kim
    Aug 2014
    Houston tx
    2,525
    And don't forget to post pics so we can see what's going on.
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
