Thread: New pool added salt 4 days after fill!
    Jan 2016
    Roanoke
    5
    New member here, just found this forum & got a little scared after reading some threads. Our pool finished/ plastered pebbletech last week (1/19/16). They acid washed the following day and they began filling it immediately. It finished filling on Saturday morning (1/23/16) (30k gallons) now the shocker is that they added salt this morning (1/27/16) 14 bags! I'm sort of freaked out since curing process is 30 days according to some threads?!?!....suggestions/recommendations please...
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,764
    Re: New pool added salt 4 days after fill!
    Its not necessarily a deal breaker for your plaster. Take a look at this thread: On Salt and Waiting 30 days
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    JoyfulNoise's Avatar
    May 2015
    13,259
    It's not optimal but your PebbleTek should be fine. It may just mean that your plaster will take longer to cure but, again, it should be fine. The sad fact is, many PBs add salt right away to newly plastered pools in contravention of the NPC Guidelines and, yet, there isn't some huge increase in plaster failures.
    Don't sweat it, your pool will survive.
    Matt
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    My PB put salt in my pool the day after it was filled and turned on the SWG. I didn't know any better and it turned out fine. At least it is still fine 3-1/2 years later.
    Jul 2011
    Arizona & California
    805
    If the plaster quality is good, adding salt early is only a minor issue. There should not be any visible problems.
    What would be nice is to inform the PB and plasterer about this article and thread on TFP: When Should Salt be Added?
    Hopefully they will realize that adding salt too soon is not the best program and provide a better product.
    Jan 2016
    Roanoke
    5
    Appreciate all the responses guys, I will pass the info on to the builder for the threads referenced above!
