Thread: Pressure switch
    Jan 2016
    Morristown tn
    1
    Pressure switch
    I have a Balboa heater on my tub and it recently began giving a Flo error. I removed the filter no change, so I adjusted the switch which corrected the problem. The error comes back after an hour or two which gets cleared of I adjust the switch( barksdale 36056) which has been replaced by a tecmark switch. Jumped the switch connection and the tub runs fine. So I purchased the new tecmark switch and it runs but does not heat. Any ideas?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Pressure switch
    I'm not the guy to answer that I'm sorry, but you'll likely get an answer pretty soon.
    I wanted to say welcome to the forum, and enjoy your time on TFP!
    Essential Links:
