Thread: Intelliflow VS Pump Cover - a good idea?
    Dec 2014
    Riverside California
    482
    Is this Intelliflow cover a good idea? Summers here can be 115 degrees. I wouldn't want my pump to overheat because of it. Getting my new Intelliflow installed tomorrow, WOOHOO!
    http://www.amazon.com/Pentair-Intell.../dp/B00CTED5GQ
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    Re: Intelliflow VS Pump Cover - a good idea?
    The fan blows from back to front, so that cover won't block the cooling. It will have to be modified to fit around the electrical connection, and it will have to be removed any time you need to access the controls to program it or manually turn the pump on/off or change speeds. I just used a storage bin from Home Depot and a ulitily knife to make a custom cover for mine. It does the exact same thing, is easier to remove/replace and only cost 8 bucks.
    chiefwej
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    I have that same one on my Jandy vs 2.0, in Florida here, no problem...
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    Far more important than weather protection is surge protection. I actually added two "whole house" surge protectors. A larger one at my main service panel protecting the incoming line and a second smaller one on the pool equipment us panel. Easy install, one afternoon, and total cost less than $150.
    chiefwej
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    sorry... wrong post
    Autopilot SWG
