Page 1 of 9 1234 ... LastLast
Results 1 to 20 of 178
Thread: Switching to Salt Water
    Jun 2014
    pensacola,fl
    104
    So the wife and I finally decided to switch to saltwater. Im having some trouble deciding on which system to get. I like pentair products but I noticed they don't have digital displays to read the salt. I was looking at the hayward aqua rite but I have read some bad reviews about them. There are more good than bad but.... My pool is 30,000 gallons. Any suggestions? I would like to stay around 1200-1300 for the system. Any help will be greatly appreciated.
    18x36 ft in ground vinyl liner pool Approximately 27000 gal. Pump is Pentair IntelliFlo variable speed pump with Hayward sand filter and Hayward Aquarite Salt System with T-15 Cell. K-2006 Test Kit
    Aug 2013
    Oklahoma City, OK
    140
    Re: Switching to Salt Water
    Aquarite has worked great for me. I did have to replace that little diode on the circuit board but that was no problem even with having no prior knowledge of how to solder!
    20000 Gallon, Sand Filter, IG Plaster, Hayward Aqua Rite 40k SWG, TF-100 Test Kit, Taylor SpeedStir
    JoyfulNoise's Avatar
    May 2015
    13,240
    Without an automation panel, a Pentair IntelliChlor (IC-60) is not really the best choice. The output can only be adjusted in 20% increments. TFP always recommends you get an SWG sized about 2X your pool volume even though the industry usually does not. Getter a bigger cell will allow you to run it a lower output % power and thereby increase the longevity of the cell. For your pool, a Hayward AquaRite with a T-15 cell will probably be the best choice. Hayward has recently updated their power supply design to correct a longstanding problem with the in-rush current limiter (thermistor) always burning out. Even though the previous fix was simple ($2 component & 15 minutes with a soldering iron), most people found it to be a nuisance. That is probably the bulk of the bad comments out there regarding the AquaRite systems. The Jandy cells are pretty good too but my biggest complaint about them is that their largest available cell produces less chlorine per day than any of the other competitors (Jandy AquaPure 1400 produces only 1.25lbs of Cl per day while the Hayward T-15's and Pentair IC-60's produce closer to 2 lbs per day).
    So, for you, it's probably either Jandy or Hayward, whichever fits your budget. Also, careful with purchasing online. Many of the pool equipment manufacturers will only honor a 6 month warranty if you self-install and/or buy online. Many times you have to buy the unit through one of their distributors and/or have it professionally installed to get the longer warranties. When you decide which cell you're going to install, check with the manufacturer on warranty limitations.
    Matt
    Jun 2014
    pensacola,fl
    104
    What if I would be able to get a pentair with automation panel. Would that be better than other two or should I just go ahead and get the hayward t-15?
    38,431
    All the big brands are very similar. If you get automaton, then you should match the SWG brand to it. But I would not say the Pentair SWG is better than the Hayward. The Pentair cells are certainly more expensive to replace.
    The key is the sizing where the Hayward might be a little on the small side.
    Jun 2014
    pensacola,fl
    104
    See that was something I've been afraid is during the summer months the 40k being too small to keep up with my pool. I live in Florida and it gets pretty hot down here and I always tend to use way more chlorine. So I was looking at possibly going with the Pentair IC60. I feel it would work less than a 40. Im looking to order it in the next week so Im trying to get all my research done this week. I know its not going to help me much right now with the way the weather has been but I'm hoping it will start warming up next month. Thanks again for all the advice.
    May 2015
    13,240
    Quote Originally Posted by curtisimo81 View Post
    In your 27,000 gallon pool, an IC-60 generating 2.0 lbs of chlorine per day will add 8.9ppm FC per day. A clean pool in a hot climate will easily use 2-3ppm FC per day but more likely closer to 4 ppm/day. Add kids and a big pool party and you could easily overwhelm the output of the SWG. So, no matter what brand you choose, you'll still be using bleach to supplement your SWG. Even I, with my tiny 16,000 gallon pool, supplement with bleach every so often. If you have to add an automation panel to an IC60 then you're talking way over $1,300.
    Have you considered a Stenner pump as a possible solution?
    Matt
    Jun 2014
    pensacola,fl
    104
    I honestly haven't even looked at the Stenner pump. I'm going to research it now.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Both the IC60 and the AquaRite AQR15 put out a maximum of 2lb per day, so it would seem that although one is rated at 60k gallons and the other at 40k the output is the same. The replacement cells for Hayward AquaRite are significantly cheaper because the flow sensor isn't in the cell. I've been using the AquaRite for over ten years now. In a 20k pool my first t-15 cell lasted 7+ years, and cost $300 to replace making my chlorine cost $57 per year. We will see how long my second cell lasts.
    chiefwej
    38,431
    Did they change the Hayward rated output? I always thought it was 1.4 pounds per day
    May 2015
    13,240
    Don't get me wrong, I LOVE my SWG!! But they are not without cost and their own complexities. You have an IntelliFlo which is a great VS pump to own, so getting an automation panel to pair with an IC60 would be a bigger upfront investment in your pool, but a great investment in my opinion. Typically, if you decide to go with automation, the recommendation is to keep it all in the same product manufacturer. As one member of TFP put, "You can power a Chevy truck with a Ford engine and a Toyota transmission, but it's just adds unnecessary complexity."
    One thing to keep in mind with an SWG is to remember that they only generate chlorine when the pump is running. So, if you're used to short pump run times, you may find having to run the pump extra as adding to your utility bill. Let's assume you need 3ppm/day from an IC60 SWG. Based on what I wrote previously, your going to generate about 9ppm/day, so that means your pump will have to run a minimum of 8 hours each day with the SWG running at 100% power or 16 hours/day running at 50% power (SWG's run in a duty-cycle method, % power = fraction of the time the cell is ON for a given time period). The VS pump will allow you to find the minimum run speed necessary to generate chlorine (and therefore optimize your utility costs) but you'll still be running the pump a lot more than most people do using the manual chlorination method.
    Just some additional thoughts.
    Matt
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    I should have said, if both put out the same. I was just going by Matt's earlier post in the thread.
    chiefwej
    May 2015
    13,240
    The T-15 puts out 1.4lbs of Cl per day and is similar to the Pentair IC-40. The IC60 puts out 2lbs/day. The Jandy AquaPure700 puts out 0.7lbs/day and the Aquapure1400 puts out 1.25lbs per day.
    Matt
    Nov 2015
    Ok ok
    823
    I can't remember which one it was, but doesn't one have a much longer warranty then the other?
    ~14K gallon - AquaRite AQR15 SWG - pool Newly plastered on April 9 2016
    TF100 kit - STA-RITE SYSTEM3 Modular Media Filtration - Model S8M150
    Pool water supply from on site water well = CH of ~350 and TA of ~350
    Doheny's Discovery Automatic Robotic Cleaner/Pentair Model 011018 VS Pump
    Sundance Altamar Hot tub separate from pool / central Oklahoma
    May 2015
    13,240
    Quote Originally Posted by Lykly View Post
    Most manufacturers have the same warranty. Pentair will definitely extend the warranty out to 3 years BUT you typically have to make a bundled purchase with other Pentair stuff (like an IntelliFlo VS pump, an IC SWG and an automation panel). Other manufacturers offer similar deals. The one thing they also do is restrict warranties for self-installed units and products not bought through their distributors. So if you see a Pentair IC40 on Amazon and think, "WOW! That's an incredible deal!!" be careful as the warranty will usually only be 6 months.
    Matt
    Nov 2015
    Ok ok
    823
    Thank you JoyfulNoise, It must be the robot cleaners I was thinking about, one of those had a much better warranty I believe.
    Jun 2014
    pensacola,fl
    104
    What are your thoughts on ozone systems? I have a friend that has one and loves it but I don't know a lot about them except for how they work. Are they worth it or should I stay away from them. I can get a complete system installed for just under 1k. Any thoughts?
    Jun 2011
    Long Beach, CA
    2,790
    Ozone is not recommended here at TFP for outdoor residential pools. Use the search funtion and type in "ozone" and you will find a lot of information on it.
    You will get away with a Hayward Aquarite T-15 cell, but might have to run slightly longer run times in the summer to keep up. Most places still have a three year warranty even with self installs with the Aquarites. Are you planning on doing a self install?
    Another option is the Autopilot brand. They are more than what you wanted to pay, but they do havce the size and controls that you would need.
    Jun 2014
    pensacola,fl
    104
    Thank you for the info. Yes I am planning on installing myself. I just don't want to spend the money and not be happy with it. I'm just looking for a system that will require less time on my part. My wife and I both have busy work schedules and 5 kids so you can imagine we don't have a lot of time to spend tending to the pool. I like the idea of going salt it was just brought to my attention by a friend about the ozone. Didn't know if it was a good system or not.
  20. Back To Top    #20
    May 2015
    13,240
    Tell your friend to switch off his ozone system and see if there is any difference in his water quality. My guess is there will be no difference.
    Ozone, like UV systems, are good at killing certain types of pathogens that are not as easily destroyed by chlorine. However, those pathogens tend to be rarely found in single-family, low bather-load residential pools. As well, most of those alternative sanitizer systems are fairly "weak sauce" in terms of their output and installation. For example, most residential ozone generators use ambient air as the input gas for a corona discharge (CD) ozone generator. Ambient air is only 18% O2 and it contains more than enough humidity (even in "dry" climates) to severely degrade the O3 production efficiency. This is why I said to tell your friend to disconnect it as the amount of O3 generated is very small compared to the task at hand. UV is a little better but those systems often use lamps with weak output in the UV-C spectrum OR they are plumbed into the pool equipment in such as way as to degrade their performance. Both UV and Ozone need long contact times with water to have an impact. Finally, even if you were to generate strong UV or Ozone, neither of those creates a residual concentration of disinfectant and so therefore can not replace the need for chlorine and, in some cases, can actually increase your chlorine demand.
    So, on balance, those systems just become very expensive toys that you add to the equipment pad which increase cost (both installation as well as on-going expense and maintenance) with very little, measurable benefit.
    Matt
