Thread: Jandy Lite2 heater keeps blowing 2 amp fuses
    Jan 2016
    Pueblo, Colorado
    1
    Hi,
    I am having problems with my Jandy Lite2 Heater in that the igniter keeps blowing the 2 amp fuses. I traced the problem to the 115/230 VAC Conversion Plug. The plug changes 230 volts to 115 volts for the igniter. This failed three different times in that it is not changing the volts to 115. I have replaced the Power Control Board and Transformer and I still can't find what is causing this problem.
    I would appreciate any help to find my problem.
    Harold John
    In ground 18' x 30' x 4' to 9' deep pool. Heater is a 2004 Jandy Lite2 Model LJ Natural Gas. The pump is a Hayward model SP-2610X15 Self-Priming. Jandy Aqua Pure APURE35 chlorine Generating device. The pool is enclosed in a 30' x 50' arch cover green house with three 40,000 BTU natural gas radiant heaters.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Jandy Lite2 heater keeps blowing 2 amp fuses
    Welcome to the forum Harold!
    I wish I could help, but an electrician I am not.
    Essential Links:
    Casey's Avatar
    SW PA
    10,427
    Harold, welcome. Did you ever get your heater figured out?
