Thread: Why not use white pavers?
    Jan 2016
    Sarasota/FL
    1
    In Sarasota, I'm about to re-finish a small, 25 year-old, in-ground pool and adjoining spa, and re-surface the surrounding deck (currently poly-pebble).
    • The pool is on the south side of the L-shaped house, under a screen cage.
    • On the northwest and northeast sides, there's a high overhang from the roof. The pool and spa aren't under the overhang, but much of the deck is.
    • There are some very tall trees about 30 feet to the south and west, and some thick palm trees just outside the cage.
    • Because of the trees and the overhang, the pool and deck get only about 4-5 hours of direct sun during the winter, 8-10 hours during the summer. Deep under the overhang gets very little direct sun.
    I'd like to cover the poly-pebble with thin pavers, in as bright a color as possible. My contractor is warning me away from white or off-white pavers, saying that these colors will attract mold over time. True? (Pure white pavers seem hard to find, but that's another discussion.)
    Any advice would be appreciated. Thanks.
    Aug 2014
    Houston tx
    2,524
    Re: Why not use white pavers?
    I would steer away from white because of trying to keep it clean. It will definitely show the dirt! Also, I think the glare from white pavers would be a problem.
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,383
    What she said!^^^^^^^^^^^ NO white! light cream would be best.......
    Kim
    Nectarologist's Avatar
    Apr 2015
    New York
    426
    They would essentially be just like using white/standard concrete. Power washing will clean it easy. Only need a small electric one if you plan to clean it a couple of times a year. If u let it go you might need more power.
    Inground, vinyl liner, 16 x 32 (approx. 21k gallons), roman end w/ bench, 2 Jandy LED lights
    Pump: Jandy Flopro, 1.5 hp Heater: Raypak, 266k btu (P-R266-A-EN-C; nat gas) Filter: Jandy C340 (cartridge filter) Robot: Doheny's Dolphin Discovery SWCG: Circupool RJ45
