Thread: Sand filter vessel
    Jul 2015
    ARLINGTON
    7
    Sand filter vessel
    We have had a Taglius sand filter for 20 years. This year after putting the Quicrete pool filter sand in, it split open a lateral leak. Could be just age, I don't know. I do know I will not use their sand again. Never the less, in looking at replacements, the Taglius is about $500 and Permair [who makes the Taglius tank is only $265. Reviews of the Permair tend to show early failures after warranty ends. My question is why is the Taglius so much more expensive? Thicker fiberglass?
    15,000 gallon gunite built 1987. renovated whole pool decking and replastered about 10-12 years ago. Arlington, TX
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Sand filter vessel
    I don't know, but the amount of difference seems to indicate something, and the early failures would be enough for me to take pause. Just out of curiosity, what was wrong with the sand?
    Essential Links:
    Jul 2015
    ARLINGTON
    7
    Quote Originally Posted by Patrick_B View Post
    I think I read about that sand on this form. Quikrete thought it may have been bad batch or mislabeled. Any way, other people had trouble with this sand.
    My only experience was using just once. I backwashed first for a long time. It was very cloudy. When I put on filter mode all seemed okay till I saw water seeping from bottom of tank. That is when I discovered the crack which was about the sand level.
    What was interesting was when I tried to remove it. Usually my shopvac sucks it out rather easily. Not this time. I ended up using a cup and shoveling the sand out. The previous sand was still on the ground . When new sand was put on top it was much darker. The sand took a very long time to dry. Over a week. That is when I started to ask about sand.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Cloudiness is very normal, but it could vary as could the batches for all I know. I suppose I got a good batch whe. They put mine in. All 900 lbs of it.
    Essential Links:
    Jul 2015
    ARLINGTON
    7
    900 lbs. wow, how big is your pool and sand filter. What make is your filter vessel?
