Results 1 to 10 of 10
Thread: Anyone have a trick for painting the bull nose pool edge?
    Jul 2015
    Tempe, Az
    123
    All of the crummy old Zip-Strip is out! Hooray!
    Aiming to start the degrease, acid etch project this weekend, and maybe try and start painting.
    Anyone have a trick for painting the bullnose? I'd like to get the top and rounded edge, down to the tile line. Is this going to be a "lay on your stomach and reach over" manual job? Or has someone got a good trick?
    Oh - pool is filled, but 4 or 5 inches below bullnose. But the water is only 45 degrees, so I'm NOT going in there.
    28K Gallon old-skool plaster hole in the back yard in desperate need of an acid wash and a fixed skimmer diverter (yes, it's still broken)
    Hayward SuperPumpVS pushing some giant hayward cartridge filter setup
    SharcVacXL and Zodiac G2 to keep things clean
    Jun 2014
    15,298
    Re: Anyone have a trick for painting the bull nose pool edge?
    I agree. That water temp is "no bueno". You might be working on your abs this weekend. Unless you have some magical suspension tricks in your backyard.
    Jan 2015
    Austin, TX
    1,095
    Quote Originally Posted by Brett_N View Post
    I am sure you'll be working on your abs. I am wondering if you can tape lots of bubble wrap to the tile line with the blue painter's tape. The reason I say bubble wrap is it should float and you can get it fairly cheap at walmart in big rolls. That might prevent paint from falling in the water and staining the tile line.
    Pool is done! Only took 17 months! - Natural shape in-ground pool: 37x23, 505sq ft, 96ft perimeter, 7ft deep end, 18,950 gallons, tanning ledge, blue surf pebble sheen/luminous blue blend, Belgard coping, 910 sqft paver deck/walkways, retaining walls out the yinyang. Jandy SWG, 2 LED Color lights, VS 2HP Pump, 460sqft cartridge filter, PDA RS P8 controller. My build
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,672
    Mirror?? To help you see? attached to your head so you can use two hands??
    AND you KNOW you have to share a picture of what you wearing it!
    Kim
    Jul 2015
    Tempe, Az
    123
    Alright Kim just wants to see me make a fool out of myself LOL
    I like the bubble wrap idea - I didn't even think of paint overage into the pool...grumble.
    Jul 2012
    Tallahassee, FL
    30,672
    No, no, no I being helpful! REALLY hehe
    I was thinking maybe you really could figure out a way to use a mirror so you would not have hang your head over the side trying to see the underside. The bonus for us is it WOULD look kind of silly!
    Neat and good idea with the bubble wrap. You could also use Styrofoam as it floats as well.
    Kim
    Apr 2013
    Sacramento, CA
    2,769
    Why are we painting the coping? Is it already painted and looking like %&^%$#^&^%%???
    Because painting usually is just a short term solution.
    Jul 2015
    Tempe, Az
    123
    Gwegan - it was never painted - it's just bare concrete. It's not a "must do" but more of a "cosmetic - I'll like it better painted" deal, and I'm re-painting the entire patio area so this is just a piece of the puzzle. (light sand on the patio, off-white for the coping)
    I'm leaning towards the solution of just painting as much as I can now, and coming back in the warmer months and finishing off the underside.
    Jan 2015
    Austin, TX
    1,095
    If you are doing it in the summer I am picturing you in your swimsuit in the pool with a paint brush and this on your head...
    Amazon.com: Red Drinker Beer and Soda Guzzler Helmet (Red): Toys Games
    Jul 2012
    Tallahassee, FL
    30,672
    Oh yeah! That would do the trick!
    Kim
