Results 1 to 7 of 7
Thread: PH / Chlorine using Chemigen D10
    Jan 2016
    Perth
    5
    hiya
    I have a chemigen D10 and the orp was set to around 650
    everything was good but when I test my chlorine its high around the 3 - 4
    ive keep dropping the ORP but its not doing to much
    its down to 590 and the level of chlorine is 4.5
    PH is OK around 7.5
    What happening, what am I doing wrong.
    Thanks
    Standard sand filter
    Pool 64,000 litres
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: PH / Chlorine using Chemigen D10
    Hello and welcome to the forum Judge!
    That isn't bad at all in terms of FC residual, but it really depends on what your Cya level is. I would encourage first to look at Pool School, and begin with the ABCs. From there, see what the recommended levels are that we suggest, and acquire a proper test kit to determine that. We base everything on testing your own water, and adjusting accordingly. Others will be along to elaborate, but this is where we will suggest you starting out. If you have a full and proper test kit, please post up a full set of numbers, and we can go from there.
    Essential Links:
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    I'm going to admit, in some areas I know just enough to get myself in trouble - but here goes.
    Do a little searching on the site will show that ORP is really not a reliable method of monitoring chlorine as it is affected by other parameters in the water.
    Patrick has hit the nail on the head, we base our pool care system on accurate testing and only adding what the pool needs, when it needs it. To do that you need your own accurate test kit. The problem you may have is finding a test kit based on Taylor reagents down under. This post talks about a kit that is apparently available - CCL vs TF-100 Results
    As Patrick pointed out, the first step in understand our methods and why the chlorine/CYA relationship is so important is reading ABCs of Water Chemistry
    Support the site
    Jan 2016
    Perth
    5
    Thank you for your reply
    I do have a electronic Tester and this is displaying the high chlorine reading. I do calibrate the tester often.
    its just that I am lowering the ORP setting without much change to the chlorine level as that's stayng high.
    I will test the CYA,TA,CH today
    Jan 2016
    Perth
    5
    ok tested the
    Calcium Hardness 231
    Cynuric Acid 45
    Alkalinity 129
    PH 7.5
    Chlorine 3.5
    On the controller the ORP is set on 595, PH set on 7.3
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Ok,
    How are you testing for FC, (Free Chlorine) and how are you calibrating the sensors? There are a number of things that can effect the ORP readings besides Chlorine, so it alone should not be relied on for accurate FC levels. As for the pH, how are you verifying the readout?
    Essential Links:
    Jan 2016
    Perth
    5
    Hello
    I have a palintest 6 and all the tablets that goes with it.
    The pool is stable with all the testing and I did get a third party to test it and its all OK
    its just the ORP reading that is set on about 600 now
