Results 1 to 18 of 18
Thread: Pump replacement
    Dec 2015
    Houston TX
    39
    Pump replacement
    Howdy !
    My circulation pump is dying (damaged bearings) and I would like to replace the motor.
    I noticed that the former owner of the house already replaced the motor of the pump since the pump datasheet says it's a 1.5HP and the motor is 3/4HP.
    The part# of the pump is SPX3215Z1PE (1-1/2HP)
    The part# of the motor is SP3207Z1BE (3/4HP)
    I was wondering if I could replace the whole pump instead of the motor only. At least I would start over with a brand new pump and I will not have to worry about changing the impeller if I put a new 3/4HP motor.
    Also a new motor would cost me about $200 before shipping on INYOPOOLS.COM and I noticed that it is the price of a brand new 1.5HP pump (see below):
    http://www.amazon.com/-Ground-Pool-S...l+pump+1-1%2F2
    http://www.amazon.com/XtremepowerUS-...1PJC7QZ39D649N
    Now the question is: Can I use any pump to replace the old one ? Are the dimensions the same ? Are the suction inlet and discarge outlet at the same position ?
    Thank you in advance !
    G
    Attachment 44824Attachment 44825
    Guillaume B.
    12k pool and spa spillover / In-Ground pool / Gunite pool / Swimclear cartridge filter / Hayward SPX3215Z1PE pump / Installed in 2004 / Intellichlor SWG / Hayward heater H400FDN
    Jun 2014
    15,059
    Re: Pump replacement
    Good morning. To basically answer your questions - "Yes", you can use any pump (manufacture). Swapping from a whole new unit is fine and may be more beneficial at this point. Pumps do vary in overall dimensions, but as long as it will fit on your equipment pad you should be fine. The biggest thing would be ensuring you select the correct inlet/outlet size to mate-up with your existing PVC fittings. Aside from that, just shopping on-line for the best bargain and you should be fine. Others may reply with personal recommendations to better assist. Best of luck.
    Aug 2014
    Shallotte, NC
    693
    Note that you are comparing apples and oranges. The Amazon links lead to Chinese knock-offs, not genuine Hayward pumps or motors. You can use any motor/pump, but there may be a lot of plumbing work in your future.... there may be, anyway, even if you go back with an identical unit.
    I'm going to go way out on a limb, but I really suspect that along with the motor, the prior owner changed the impeller and possibly the diffuser. Motors don't like to be overloaded and since yours seems to be running, but noisy, I'm guessing it isn't overloaded....
    Dec 2015
    Houston TX
    39
    When I opened the pump I found this part number on the diffuser (that was broken into two pieces): SPX3200B3
    http://www.amazon.com/gp/product/B00...etailpage_o00_
    I honestly think that they did not know that they had to change the impeller and swapped the motor only. I will check the impeller P/N during lunch.
    But basically buying a new motor (SPX3215Z1BER) and a new diffuser would be my best move ?
    Guillaume B.
    Aug 2014
    Shallotte, NC
    693
    Quote Originally Posted by gbraillon View Post
    That's going to depend on a lot of things. How handy and comfortable you are with taking on the project, compared to the various replacement costs. Check the impeller part number, too.....
    Oct 2015
    Katy/Texas
    411
    Buying the cheap knockoffs provide a false economy. Properly installed and operated quality pumps will last for years. The pentair pump for my pool has been in service for 20 years. I am only considering replacement with a new 2 speed for the energy savings.
    In ground, 14,000 gallon, white plaster, unheated, stone waterfall, DE Filter, Rainbow 320 Cl, Polaris 3900, FloVis flow meter, F100 test kit, Circupool RJ30+ SWG, Circupool VJ1/Speck Badu EcoM3V variable speed pump.
    Dec 2015
    Houston TX
    39
    Quote Originally Posted by ewkearns View Post
    Just checked it says SPX3207C so I guess they did replaced the impeller. Right now I am thinking about replacing the motor AND the broken diffuser. What is the benefit of having a 1.5HP instead of 3/4HP ? I noticed that the flow is acceptable with one skimmer only but if I open the valve to have two skimmers lined up it doesn't suck the debris very well. Would that be the cause ?
    I found a 1.5HP motor at $285 on Amazon (SPX3215Z1BER) and a diffuser at $30. I will have to buy a new impeller for 1.5HP as well.
    I also found a Hayward SPX3215Z1PE 1.5HP Power end (that includes motor, diffuser, impeller, etc...) for $336 on Sears.com
    Maybe that's better deal and it's easier to replace since it's almost plug-and-play.
    Guillaume B.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,318
    If the pump is 1.5hp, the old motor 3/4hp and with both skimmers engaged is a weak draw, I would
    get a 1.5hp motor to replace and match it up to a 1.5hp diffuser and impeller.
    get a good name brand motor, not some cheaper unknown brand that may very well fail early.
    Don't forget to get a new seal kit so you have all brand new seals in the pump.
    And before ordering the motor verify if the old motor is wired as 110 or 220
    Dolphin E10 Cleaning Robot.
    Dec 2015
    Houston TX
    39
    To me this looks like the best option: http://www.sears.com/hayward-spx3215...-SPM7744328203
    It was wired as 120V
    Guillaume B.
    Aug 2014
    Shallotte, NC
    693
    That appears to be an AWESOME price, but I question shipping cost vs. delivery times and whether it carries a valid manufacturer's warranty. I've never heard of UnbeatableSale.com, Inc.
    Dec 2015
    Houston TX
    39
    Shipping is free and it says Delivery on Feb 12th which is totally acceptable since I do not need to run the pump these days.
    Guillaume B.
    Aug 2014
    Shallotte, NC
    693
    The fine print always worries me: "Free Shipping OR get it as early as..." and the link to the warranty sorta dumps you in the creek. But, I gotta admit, the price is stellar! Let us know how this plays out.... I'm sure other readers would like access to essentially half-price motors, too....
    Dec 2015
    Houston TX
    39
    UPS Tracking says delivery on Feb 4th ! It sounds even better like that! I will keep you posted about the warranty thing but I believe it should come with a warranty from Hayward.
    Also I noticed that the pump was not bolted to the pad. It was just held by the pipes. Do you guys recommend to bolt it or is it not necessary ?
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,318
    Shouldn't need to bolt it down...just make sure there is no tension/weight pulling on the pipes.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Most do not bolt their pumps down. Some do in earthquake prone areas.
    Dec 2015
    Houston TX
    39
    Awesome ! I should be getting the new motor today. I will try to install it this weekend and I will let you know how it goes !
    Guillaume B.
    Dec 2015
    Houston TX
    39
    Soooo here is the new pump: https://www.youtube.com/watch?v=eiqD9GSAVd0
    It sounds so peaceful
    Also I noticed the pressure on the gauge of the filter went from 10PSI (when I had a 3/4HP) to 18PSI with the new pump. My guess is that it's a normal behavior but I just want to double-check with you guys.
    Guillaume B.
    Aug 2014
    Shallotte, NC
    693
    Looks good to me...... and I would expect the pressure to be greater than the older, smaller pump.
