Results 1 to 9 of 9
Thread: No pressure from catridge filter
    I recently changed the catridge filter I my ZX hurlcon filter and now it's reading zero pressure and creep crawly is not moving. The water is circulating fine and there is still quite a bit of suction from creepy crawly. Any idea why the gauge is reading no pressure. Cheers steve
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,379
    Re: No pressure from catridge filter
    Do you have your old cartridge? If so I would put it back in and see what happens. If no I would take the new one out and make sure you put in right. I would also look to make sure nothing came off the new filter that got caught in the gauge.
    When you say the water is circulating fine what are you basing that on? Did you put your hand in the water in front of one of the returns?
    How old is your gauge? Are you sure it still works?
    Sorry for all of the questions. Trying to get a baseline to work from.
    Kim
    Hi Kim, I tried putting old catridge in but still no pressure on gauge. Yep I put my hand over returns and flow seems ok.
    I'll check that nothing is caught in the gauge. The gauge is about 6 years old.
    Cheers
    Steve
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    Might be time for a TFP Glycerin filled gauge!
    Dolphin E10 Cleaning Robot.
    Apr 2013
    Sacramento, CA
    2,769
    As borjis says you probably need a new gauge. But first take the old one off and inspect it. Remove any crud that may be blocking it. Blow into it and run it under some water and see if that changes things. Even if the cartridges are improperly installed you should be getting some presure reading.
    Jul 2012
    Tallahassee, FL
    30,379
    New gauge then! Let us know what that does or at least the cleaning/checking of the old one.
    Kim
    Ok thanks for advice. Will investigate the gauge this weekend.
    Cheers
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    If you do decide on a new gauge TFTestkits.net has a fancy oil filled gauge for 11 bucks.
    I took the gauge off and gave it a clean. Appears to be working now.
    Thanks
