Results 1 to 9 of 9
Thread: Thinking of Going O/B Plz Help
    Nov 2015
    IE , CA
    12
    Ok So heres where im at i signed contract with a company the did the design and engineering and are ready to start building the pool; but we are already not happy with their customer service seems like as soon as contract was signed the customer service went out the window. so was considering canceling the contract and building myself what would i need to do that are you guys signing up with those websites that claim to help or are you using this forum plz help.
    In Ground 15'x30'
    Pentair VS pump
    Pentair CCP320
    Pentair intellichlor SWG
    Pentair Master Temp Heater 400,000 btu
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Thinking of Going O/B Plz Help
    I'm not sure what most have been doing but there have been quite a few OBs popping up here lately. More than I ever remember before. If you look around there a a few current threads in various stages.
    Welcome to TFP, by the way and enjoy the forum.
    Essential Links:
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,741
    Where are you located?
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Nov 2015
    IE , CA
    12
    Inland empire area close to san bernardino
    In Ground 15'x30'
    Pentair VS pump
    Pentair CCP320
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,741
    Where are you in the process? Are you keeping the design or starting over? What makes you want to go the owner/builder route?
    Keep in mind that although this site is very DIY friendly, the bulk of that pertains to pool care and basic maintenance mainly due to the huge misconceptions in the pool industry regarding water chemistry. There is no advocation for or against pool builders or the owner/builder route. That is a decision you will need to make.
    -Brian-
    POOL BUILD
    Nov 2015
    IE , CA
    12
    i want to keep the builder confidential. but i am thinking of using the same design. my reasons for wanting to terminate them is the way they been treating us when we ask any questions just makes me wonder if its bad already and they havent even started what will it be when they do start
    In Ground 15'x30'
    Pentair VS pump
    Pentair CCP320
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,439
    Good move on not naming names. Be very vague about the whos and wheres.
    THANKS!
    Kim
    Sep 2012
    Los Angeles
    99
    I went the owner builder route and I am in So Cal. Luckily for us, there is a huge swimming pool construction industry locally, with a huge amount of subcontractors to choose from. Take a look at my build thread for more info. My two cents, if you have the time to oversee the subs, and educate yourself on the order of the subs and what to look for during each step, you will end up with a higher quality finish for your pool for the same amount of $$. Good luck!
    Rectangular pool 28x16 and spa 8x7, 17,000 gallons, IG, Tropics Blue Mini-Pebble, Jandy 60 DE filter, saltwater cell, Jandy VS pump, 1.5 hp Jandy spa pump, 400k heater, 5' Sheer Descent with 1 hp Jandy pump, Jandy color LED lights. Build Thread
    Nov 2015
    IE , CA
    12
    Sent u email bdavis
    In Ground 15'x30'
    Pentair VS pump
    Pentair CCP320
