Right now I have my Stenner (230 v) wired such that my filter pump relay outputs are tapped off and feed an Aux relay that the Stenner gets its power from in my Easy Touch so that my Stenner cannot run unless the filter pump is on. I am planning on getting a VS pump in the near future and wonder if there is any way to wire up my Stenner so that it cannot run unless the VS pump is running. The VS pump will be fed with a constant 230 V and be turned of and off via the Data Cable to the Easy Touch. I can not think up a way to do this, but mabe someone else has had this problem and found a solution. Thanks!
